소개
Use this guide to replace the brake light bulb on the Hyundai Santa Fe Sport.
The brake lights are something that frequently needs replacing compared to other parts and it is important to make sure your brake lights are functioning properly. It will become dangerous to drive around in a car with no brake lights.
There are many other light bulbs to be used as brake lights available, but the one I recommend is the Sylvia 2357 long life mini bulb.
필요한 것
Remove the black plastic cover located on the inner side taillight by using a #2 flat head screwdriver.
You have now completed the guide, to replace the brake bulb on your 2012 - 2018 Hyundai Santa Fe Sport.
다른 5명이 해당 안내서를 완성하였습니다.
댓글 2개
Follow these steps and you can't go wrong. Nicely done.
