필요한 것
Using both latches on the left and right side of the Thinkpad, lift up the screen.
Again using both latches, push them back while pushing the keyboard up till it pops up, then lift the keyboard up. You may need to use a little force.
Lift the battery using it's cloth pull tab and lift it out of the ThinkPad. Set it aside.
Remove the following screws, there should be 3. Two of the screw spots may be slightly different on yours.
The cover has adhesive on it at these spots, pull it slowly till the adhesive releases. Then lift the cover up, you may need to hold it.
Disconnect or remove the cable located above the drive, be careful as the cable is fragile.
Your drive should have 2 screws holding it down, remove them. They are small so keep track of them!
