주요 콘텐츠로 건너뛰기
이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
IBM ThinkPad 560z Hard Drive Replacement
필요한 것
  1. IBM ThinkPad 560z Hard Drive Replacement, Upper Case: 1 단계, 이미지 1/1
    • Remove the 7 mm Phillips #0 screws.
    • Remove the 10 mm Phillips #0 screws.
    • Remove the 14 mm Phillips #0 screw.
  2. IBM ThinkPad 560z Hard Drive Replacement: 2 단계, 이미지 1/2 IBM ThinkPad 560z Hard Drive Replacement: 2 단계, 이미지 2/2
    • Open the flap on the left hand side.
  3. IBM ThinkPad 560z Hard Drive Replacement: 3 단계, 이미지 1/2 IBM ThinkPad 560z Hard Drive Replacement: 3 단계, 이미지 2/2
    • Insert the plastic opening tools between the right and left sides of the latch.
    • Pry the right side of the latch, and then pry the left side to detach the laptop's cover.
  4. IBM ThinkPad 560z Hard Drive Replacement: 4 단계, 이미지 1/2 IBM ThinkPad 560z Hard Drive Replacement: 4 단계, 이미지 2/2
    • Open the flap on the right side.
  5. IBM ThinkPad 560z Hard Drive Replacement: 5 단계, 이미지 1/1
    • Insert the plastic opening tools towards the right side of the latch.
    • Gently pry the right side out to release the top cover.
  6. IBM ThinkPad 560z Hard Drive Replacement: 6 단계, 이미지 1/2 IBM ThinkPad 560z Hard Drive Replacement: 6 단계, 이미지 2/2
    • Lift the keyboard slowly.
    • A cable connects the keyboard to the motherboard. If you are not careful, you will damage the cable.
  7. IBM ThinkPad 560z Hard Drive Replacement: 7 단계, 이미지 1/1
    • Use your fingers or a spudger to detach the connector.
  8. IBM ThinkPad 560z Hard Drive Replacement: 8 단계, 이미지 1/2 IBM ThinkPad 560z Hard Drive Replacement: 8 단계, 이미지 2/2
    • Carefully lift and remove the keyboard.
  9. IBM ThinkPad 560z Hard Drive Replacement, Hard Disk Drive: 9 단계, 이미지 1/1
    • On the back of the computer, use a Flathead screwdriver to remove this lone screw.
  10. IBM ThinkPad 560z Hard Drive Replacement: 10 단계, 이미지 1/2 IBM ThinkPad 560z Hard Drive Replacement: 10 단계, 이미지 2/2
    • After the screw is out, gently remove the cover.
  11. IBM ThinkPad 560z Hard Drive Replacement: 11 단계, 이미지 1/3 IBM ThinkPad 560z Hard Drive Replacement: 11 단계, 이미지 2/3 IBM ThinkPad 560z Hard Drive Replacement: 11 단계, 이미지 3/3
    • Turn the computer back over so the hard drive faces up. Remove the shown screw with a Phillips screwdriver.
  12. IBM ThinkPad 560z Hard Drive Replacement: 12 단계, 이미지 1/1
    • Make sure you are grounded and detach the IDA cable connecting the hard disk to the motherboard.
  13. IBM ThinkPad 560z Hard Drive Replacement: 13 단계, 이미지 1/2 IBM ThinkPad 560z Hard Drive Replacement: 13 단계, 이미지 2/2
    • Remove the final two screws (shown) and slide out the hard drive.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Derek Driscoll
회원 가입일: 04/15/10
119 평판
안내서 8개 작성하였습니다
Cal Poly, Team 26-27, Regan Spring 2010 Cal Poly, Team 26-27, Regan Spring 2010 회원
CPSU-REGAN-S10S26G27
3 회원들
안내서 18개 작성하였습니다
댓글 한 개
You don't have to go to this length to remove the hard drive on a 560Z. Only do steps 0 (remove battery), 9 (remove screw) and 10 (remove cover). Then simply grab the blue tab of the hard drive caddy and pull the drive out of the bay. Complete directions on maintenance of the IBM Thinkpad 560Z can be found here:
http://www.thinkpads.com/support/hmm/hmm...
The Hardware Maintenance Manual has all of the information you need to take a 560Z apart and put it back together.
The procedure outlined here is similar to what the 560, 560E and 560X systems required; the 560Z is totally different when removing the hard drive.
Raymond - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 10
전체 시간: 3,829
