주요 콘텐츠로 건너뛰기
IBM ThinkPad 560z Keyboard Replacement
필요한 것
  1. IBM ThinkPad 560z Keyboard Replacement, Upper Case: 1 단계, 이미지 1/1
    • Remove the 7 mm Phillips #0 screws.
    • Remove the 10 mm Phillips #0 screws.
    • Remove the 14 mm Phillips #0 screw.
  2. IBM ThinkPad 560z Keyboard Replacement: 2 단계, 이미지 1/2 IBM ThinkPad 560z Keyboard Replacement: 2 단계, 이미지 2/2
    • Open the flap on the left hand side.
  3. IBM ThinkPad 560z Keyboard Replacement: 3 단계, 이미지 1/2 IBM ThinkPad 560z Keyboard Replacement: 3 단계, 이미지 2/2
    • Insert the plastic opening tools between the right and left sides of the latch.
    • Pry the right side of the latch, and then pry the left side to detach the laptop's cover.
  4. IBM ThinkPad 560z Keyboard Replacement: 4 단계, 이미지 1/2 IBM ThinkPad 560z Keyboard Replacement: 4 단계, 이미지 2/2
    • Open the flap on the right side.
  5. IBM ThinkPad 560z Keyboard Replacement: 5 단계, 이미지 1/1
    • Insert the plastic opening tools towards the right side of the latch.
    • Gently pry the right side out to release the top cover.
  6. IBM ThinkPad 560z Keyboard Replacement: 6 단계, 이미지 1/2 IBM ThinkPad 560z Keyboard Replacement: 6 단계, 이미지 2/2
    • Lift the keyboard slowly.
    • A cable connects the keyboard to the motherboard. If you are not careful, you will damage the cable.
  7. IBM ThinkPad 560z Keyboard Replacement: 7 단계, 이미지 1/1
    • Use your fingers or a spudger to detach the connector.
  8. IBM ThinkPad 560z Keyboard Replacement: 8 단계, 이미지 1/2 IBM ThinkPad 560z Keyboard Replacement: 8 단계, 이미지 2/2
    • Carefully lift and remove the keyboard.
  9. IBM ThinkPad 560z Keyboard Replacement, Keyboard Removal: 9 단계, 이미지 1/2 IBM ThinkPad 560z Keyboard Replacement, Keyboard Removal: 9 단계, 이미지 2/2
    • Remove the five Phillips screws from the underside of the keyboard, then gently lift it up.
결론
Derek Driscoll
회원 가입일: 04/15/10
119 평판
안내서 8개 작성하였습니다
Cal Poly, Team 26-27, Regan Spring 2010 Cal Poly, Team 26-27, Regan Spring 2010 회원
CPSU-REGAN-S10S26G27
3 회원들
안내서 18개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 20
전체 시간: 2,434
