이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Slide the battery release latch to the right.
Pull out the battery out towards the front of the device.
Remove the plastic screw covers, then remove the 3 Phillips screws under them.
Insert the plastic opening tool between the front cover and back cover to pry open the screen case, then carefully pull the bezel off.
Using your fingers or an Opening Tool, detach the connector on the right side of the screen.
Slowly pull back the screen from the top and disconnect the ribbon cable from the back to completely free the screen from the laptop.
다른 2명이 해당 안내서를 완성하였습니다.
