소개
This guide will show you how to replace your display from your laptop. You would need to replace it if you break your display.
필요한 것
이 단계에 사용된 도구:Anti-Static Wrist Strap$7.95
Unscrew the coin screw for the hard drive using a coin. Pry off the HDD cover.
Remove the plastic part attached to the bottom of the screen.
Gently pull it from one side and then from another.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
