주요 콘텐츠로 건너뛰기
IBM ThinkPad 600E Hard Drive Disk Replacement
필요한 것
  1. IBM ThinkPad 600E Hard Drive Disk Replacement, Battery: 1 단계, 이미지 1/3 IBM ThinkPad 600E Hard Drive Disk Replacement, Battery: 1 단계, 이미지 2/3 IBM ThinkPad 600E Hard Drive Disk Replacement, Battery: 1 단계, 이미지 3/3
    • Flip the laptop over and find the battery latch.
  2. IBM ThinkPad 600E Hard Drive Disk Replacement: 2 단계, 이미지 1/1
    • Move the latch to the side with the unlocked symbol.
  3. IBM ThinkPad 600E Hard Drive Disk Replacement: 3 단계, 이미지 1/3 IBM ThinkPad 600E Hard Drive Disk Replacement: 3 단계, 이미지 2/3 IBM ThinkPad 600E Hard Drive Disk Replacement: 3 단계, 이미지 3/3
    • Pry the battery out using your fingers.
  4. IBM ThinkPad 600E Hard Drive Disk Replacement, Hard Drive Disk: 4 단계, 이미지 1/1
    • Put on the anti-static wrist trap and clip it to a large metal object.
    • If you do not have an anti-static wristband, make sure to touch a large metal object to ground yourself before beginning to work on your replacement. Occasionally touch the metal object.
  5. IBM ThinkPad 600E Hard Drive Disk Replacement: 5 단계, 이미지 1/3 IBM ThinkPad 600E Hard Drive Disk Replacement: 5 단계, 이미지 2/3 IBM ThinkPad 600E Hard Drive Disk Replacement: 5 단계, 이미지 3/3
    • Using a coin, remove the coin screw by turning counterclockwise.
    • It's best to use a thicker coin, such as a nickel.
  6. IBM ThinkPad 600E Hard Drive Disk Replacement: 6 단계, 이미지 1/1
    • Using a plastic spudger, pry off the plastic cover by pulling it out.
  7. IBM ThinkPad 600E Hard Drive Disk Replacement: 7 단계, 이미지 1/3 IBM ThinkPad 600E Hard Drive Disk Replacement: 7 단계, 이미지 2/3 IBM ThinkPad 600E Hard Drive Disk Replacement: 7 단계, 이미지 3/3
    • Utilizing your fingers, untuck the tab and pull to remove the hard drive.
  8. IBM ThinkPad 600E Hard Drive Disk Replacement: 8 단계, 이미지 1/3 IBM ThinkPad 600E Hard Drive Disk Replacement: 8 단계, 이미지 2/3 IBM ThinkPad 600E Hard Drive Disk Replacement: 8 단계, 이미지 3/3
    • Using a screwdriver, remove the screws by turning them counterclockwise to remove the bracket.
    • four 3mm PH0 screws
    • The metal bracket is still attached with a weak adhesive tape, gently pry it off with a spudger.
  9. IBM ThinkPad 600E Hard Drive Disk Replacement: 9 단계, 이미지 1/2 IBM ThinkPad 600E Hard Drive Disk Replacement: 9 단계, 이미지 2/2
    • The top plastic piece is adhered with a weak adhesive. Gently pry it off with a spudger.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Kevin Nguyen
회원 가입일: 10/04/16
722 평판
안내서 4개 작성하였습니다
USF Tampa, Team 1-4, Nance Fall 2016 USF Tampa, Team 1-4, Nance Fall 2016 회원
USFT-NANCE-F16S1G4
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 52
전체 시간: 3,149
