주요 콘텐츠로 건너뛰기
IBM ThinkPad A30 Fan Replacement
필요한 것
  1. IBM ThinkPad A30 Fan Replacement, Battery: 1 단계, 이미지 2개 중 1개 IBM ThinkPad A30 Fan Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Flip the ThinkPad over so that it is upside down.
    • Slide the highlighted tab to the left.
    • With your finger on the tab, remove the battery by lifting it upwards away from the laptop.
  2. IBM ThinkPad A30 Fan Replacement, Upper Case: 2 단계, 이미지 1개 중 1개
    • Make sure the laptop is upside down and oriented in the direction shown.
    • Remove the six 16.7mm screws inside the circled holes.
  3. IBM ThinkPad A30 Fan Replacement: 3 단계, 이미지 1개 중 1개
    • Rotate the ThinkPad so that the hard drive bay is facing you.
    • Remove the black cover to reveal a 14.8mm screw.
    • Remove the uncovered screw with a Phillips #0 screwdriver.
  4. IBM ThinkPad A30 Fan Replacement: 4 단계, 이미지 2개 중 1개 IBM ThinkPad A30 Fan Replacement: 4 단계, 이미지 2개 중 2개
    • Flip the ThinkPad over and open the LCD panel.
    • Pry apart the keyboard with a plastic opening tool or with your fingers.
  5. IBM ThinkPad A30 Fan Replacement: 5 단계, 이미지 3개 중 1개 IBM ThinkPad A30 Fan Replacement: 5 단계, 이미지 3개 중 2개 IBM ThinkPad A30 Fan Replacement: 5 단계, 이미지 3개 중 3개
    • Be careful not to pull out the keyboard carelessly; there is a connector underneath it!
    • Lift the front end of the keyboard as shown.
    • Using your fingers, remove the black film cover.
  6. IBM ThinkPad A30 Fan Replacement: 6 단계, 이미지 3개 중 1개 IBM ThinkPad A30 Fan Replacement: 6 단계, 이미지 3개 중 2개 IBM ThinkPad A30 Fan Replacement: 6 단계, 이미지 3개 중 3개
    • Locate the connector attached to the motherboard.
    • Disconnect the ribbon cable by removing the connector.
  7. IBM ThinkPad A30 Fan Replacement: 7 단계, 이미지 2개 중 1개 IBM ThinkPad A30 Fan Replacement: 7 단계, 이미지 2개 중 2개
    • Lift and remove the keyboard.
    • Remove the two 5.6mm screws.
    • Remove the 16.7mm screw.
  8. IBM ThinkPad A30 Fan Replacement: 8 단계, 이미지 3개 중 1개 IBM ThinkPad A30 Fan Replacement: 8 단계, 이미지 3개 중 2개 IBM ThinkPad A30 Fan Replacement: 8 단계, 이미지 3개 중 3개
    • You will need to use a little force. Be wary of the tabs.
    • Pry off the upper case with your hands.
  9. IBM ThinkPad A30 Fan Replacement, Display Assembly: 9 단계, 이미지 1개 중 1개
    • Remove the 5.6mm screw that holds the LCD to the upper case.
  10. IBM ThinkPad A30 Fan Replacement: 10 단계, 이미지 3개 중 1개 IBM ThinkPad A30 Fan Replacement: 10 단계, 이미지 3개 중 2개 IBM ThinkPad A30 Fan Replacement: 10 단계, 이미지 3개 중 3개
    • Remove the 5.6mm screw on the left side of the three-pronged connector.
    • Remove the other two 16.7mm screws.
    • Lift and remove connector.
  11. IBM ThinkPad A30 Fan Replacement: 11 단계, 이미지 2개 중 1개 IBM ThinkPad A30 Fan Replacement: 11 단계, 이미지 2개 중 2개
    • Pull out the white tab connecting the LCD to the motherboard.
  12. IBM ThinkPad A30 Fan Replacement: 12 단계, 이미지 2개 중 1개 IBM ThinkPad A30 Fan Replacement: 12 단계, 이미지 2개 중 2개
    • Turn the laptop so that the back is facing you.
    • Remove the four 5.6mm long screws.
  13. IBM ThinkPad A30 Fan Replacement: 13 단계, 이미지 3개 중 1개 IBM ThinkPad A30 Fan Replacement: 13 단계, 이미지 3개 중 2개 IBM ThinkPad A30 Fan Replacement: 13 단계, 이미지 3개 중 3개
    • Place the laptop so that the LCD is facing you again.
    • Gently lift the LCD monitor up and out.
    • Remove the black plastic tab.
  14. IBM ThinkPad A30 Fan Replacement, Fan: 14 단계, 이미지 1개 중 1개
    • Remove the following screws from the fan retention bracket:
    • Single 5.6 mm screw.
    • Three 16.1 mm screws.
  15. IBM ThinkPad A30 Fan Replacement: 15 단계, 이미지 1개 중 1개
    • Lift the heatsink bracket up.
  16. IBM ThinkPad A30 Fan Replacement: 16 단계, 이미지 3개 중 1개 IBM ThinkPad A30 Fan Replacement: 16 단계, 이미지 3개 중 2개 IBM ThinkPad A30 Fan Replacement: 16 단계, 이미지 3개 중 3개
    • Be careful not to pull too hard. There is a cable attached to the fan.
    • Lift the fan/heatsink assembly up.
    • Locate the fan power cable and pull upwards near the connector.
    • Remove the fan/heatsink assembly.
결론
작성자
13다른 기여자 명과 함께
Jessica
회원 가입일: 10/06/10
162 평판
안내서 7개를 작성함
Cal Poly, Team 4-44, Amido Fall 2010 Cal Poly, Team 4-44, Amido Fall 2010 회원
CPSU-AMIDO-F10S4G44
4 회원들
안내서 26개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 8
전체 시간: 2,774
