주요 콘텐츠로 건너뛰기
IBM ThinkPad A31 Display Replacement
필요한 것
  1. IBM ThinkPad A31 Display Replacement, Keyboard: 1 단계, 이미지 1/3 IBM ThinkPad A31 Display Replacement, Keyboard: 1 단계, 이미지 2/3 IBM ThinkPad A31 Display Replacement, Keyboard: 1 단계, 이미지 3/3
    • The sticker is to keep the warranty on the laptop so once removed the warranty is void
    • Peel the sticker and remove the 15mm screw
    • Remove all 6 of the 16mm screws
  2. IBM ThinkPad A31 Display Replacement: 2 단계, 이미지 1/2 IBM ThinkPad A31 Display Replacement: 2 단계, 이미지 2/2
    • use a prying tool and insert it on the cracks on the sides of the keyboard and lift gently until you here a click
    • repeat this step on all sides of the keyboard until the keyboard is completely detached from the laptop
  3. IBM ThinkPad A31 Display Replacement: 3 단계, 이미지 1/3 IBM ThinkPad A31 Display Replacement: 3 단계, 이미지 2/3 IBM ThinkPad A31 Display Replacement: 3 단계, 이미지 3/3
    • Lift the keyboard and remove the keyboard ribbon cable from the laptop
  4. IBM ThinkPad A31 Display Replacement, Display: 4 단계, 이미지 1/2 IBM ThinkPad A31 Display Replacement, Display: 4 단계, 이미지 2/2
    • Remove the one 21mm screw
    • Remove the 6mm screw
  5. IBM ThinkPad A31 Display Replacement: 5 단계, 이미지 1/2 IBM ThinkPad A31 Display Replacement: 5 단계, 이미지 2/2
    • Take the tool and run it under the black case.
  6. IBM ThinkPad A31 Display Replacement: 6 단계, 이미지 1/3 IBM ThinkPad A31 Display Replacement: 6 단계, 이미지 2/3 IBM ThinkPad A31 Display Replacement: 6 단계, 이미지 3/3
    • Unscrew the 2 (17mm) screws
    • Unscrew the 6mm screw
  7. IBM ThinkPad A31 Display Replacement: 7 단계, 이미지 1/2 IBM ThinkPad A31 Display Replacement: 7 단계, 이미지 2/2
    • Gently disconnect the white display ribbon cable
    • Pulling on the ribbon cable too hard could result in worse or faulty connection.
  8. IBM ThinkPad A31 Display Replacement: 8 단계, 이미지 1/3 IBM ThinkPad A31 Display Replacement: 8 단계, 이미지 2/3 IBM ThinkPad A31 Display Replacement: 8 단계, 이미지 3/3
    • Unscrew 4 (6mm) screws
    • Lift screen straight up
    • If not lifted straight up the screen could get damaged
결론
Sean Tocci
회원 가입일: 03/19/18
293 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team S2-G2, Bernier Spring 2018 UMass Dartmouth, Team S2-G2, Bernier Spring 2018 회원
UMASSD-BERNIER-S18S2G2
3 회원들
안내서 10개 작성하였습니다
댓글 한 개
i have that but display is
not work
Ahmed Elwy - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 18
전체 시간: 493
