주요 콘텐츠로 건너뛰기
IBM ThinkPad R40 Fan Replacement
필요한 것
  1. IBM ThinkPad R40 Fan Replacement, Fan: 1 단계, 이미지 1/1
    • Remove the screws shown. These screws are connected to the keyboard.
  2. IBM ThinkPad R40 Fan Replacement: 2 단계, 이미지 1/1
    • Take the spudger tool, go around the edges of the oranges boxes shown, and pop off those two sections. Then, go around the edges of the keyboard, and it should slide off.
  3. IBM ThinkPad R40 Fan Replacement: 3 단계, 이미지 1/2 IBM ThinkPad R40 Fan Replacement: 3 단계, 이미지 2/2
    • Lift and move keyboard aside to get to screws. Try not to remove the attached ribbon.
    • Remove the screws shown. These screws will allow you to loosen the fan. Be careful since there is still another part connected.
  4. IBM ThinkPad R40 Fan Replacement: 4 단계, 이미지 1/1
    • Carefully unplug the highlighted part, and your fan should come straight out.
  5. IBM ThinkPad R40 Fan Replacement: 5 단계, 이미지 1/1
    • The section in blue is where your new fan will go.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Aaron
회원 가입일: 03/12/14
134 평판
안내서 1개 작성함
UMass Dartmouth, Team 2-2, Vijaybhaskar Spring 2014 UMass Dartmouth, Team 2-2, Vijaybhaskar Spring 2014 회원
UMASSD-VIJAYBHASKAR-S14S2G2
4 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 15
전체 시간: 2,854
