주요 콘텐츠로 건너뛰기
IBM ThinkPad R40 Keyboard Keys Replacement
필요한 것
  1. IBM ThinkPad R40 Keyboard Keys Replacement, Disconnection: 1 단계, 이미지 1개 중 1개
    • Make sure your laptop is off and disconnected from the power source to ensure safety for yourself.
  2. IBM ThinkPad R40 Keyboard Keys Replacement, Replacement: 2 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Locate the key that needs replacing. Use tweezers to slowly pull the key off the keyboard. Doing this will expose the underside of the keyboard.
  3. IBM ThinkPad R40 Keyboard Keys Replacement, Set aside: 3 단계, 이미지 1개 중 1개
    • Step 3: Set the old key aside and have the new key ready to be inserted onto the computer. The key has three parts, which you can see here.
  4. IBM ThinkPad R40 Keyboard Keys Replacement, Moving inside: 4 단계, 이미지 1개 중 1개
    • The new key will have an empty slot where they key used to be. It contains a small rubber spring. After the rubber spring is inserted take the new key and line it up according to the color springs on the backside of the key along with the keyboard.
  5. IBM ThinkPad R40 Keyboard Keys Replacement, Lining up: 5 단계, 이미지 1개 중 1개
    • After lining the key up, the black and white pieces will line up.
  6. IBM ThinkPad R40 Keyboard Keys Replacement, Finishing up: 6 단계, 이미지 1개 중 1개
    • Step 6: The key should not be firmly locked into place and functioning normally.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Erin
회원 가입일: 09/08/11
231 평판
안내서 2개를 작성함
University of Maine, Team 1-13, Diaz Fall 2011 University of Maine, Team 1-13, Diaz Fall 2011 회원
UMAINE-DIAZ-F11S1G13
1 회원
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 25
전체 시간: 4,899
