소개
Use this guide to replace the battery for your IBM ThinkPad T30. Battery replacement may solve issues related to performance, battery life, charging times, and other hardware functions. No special skills or tools are required for this short replacement. Before beginning the guide, ensure the device is off and power supply is unplugged.
Flip the ThinkPad upside down with the bottom facing you.
Slide the latch to the right into the unlock position.
While holding the latch in the unlock position, lift the battery out with your other hand.
다른 2명이 해당 안내서를 완성하였습니다.
