소개
Use this guide to replace your hard drive.
도구
부품
지정된 부품이 없습니다.
Flip the ThinkPad upside down with the bottom facing you.
Slide the latch on the underside of the ThinkPad to the right into the unlock position.
While holding the latch in the unlock position, lift the battery out with your other hand.
Flip to the back of the Thinkpad and focus on the screw in the bottom left corner of the Thinkpad.
Unscrew the 11mm Phillips #0 screw with a Phillips #0 screwdriver.
To reassemble your device with a new hard drive, follow these instructions in reverse order with a new hard drive replacing the old one.
다른 11명이 해당 안내서를 완성하였습니다.
