주요 콘텐츠로 건너뛰기
IBM ThinkPad T30 Hard Drive Replacement
필요한 것
  1. IBM ThinkPad T30 Hard Drive Replacement, Battery: 1 단계, 이미지 1/3 IBM ThinkPad T30 Hard Drive Replacement, Battery: 1 단계, 이미지 2/3 IBM ThinkPad T30 Hard Drive Replacement, Battery: 1 단계, 이미지 3/3
    • Make sure the ThinkPad is off and the power supply is unplugged.
    • Flip the ThinkPad upside down with the bottom facing you.
    • Slide the latch to the right into the unlock position.
    • While holding the latch in the unlock position, lift the battery out with your other hand.
  2. IBM ThinkPad T30 Hard Drive Replacement, Hard Drive: 2 단계, 이미지 1/1
    • Flip to the back of the Thinkpad.
    • Remove the single 11 mm screw using the Phillips #0 screwdriver.
  3. IBM ThinkPad T30 Hard Drive Replacement: 3 단계, 이미지 1/3 IBM ThinkPad T30 Hard Drive Replacement: 3 단계, 이미지 2/3 IBM ThinkPad T30 Hard Drive Replacement: 3 단계, 이미지 3/3
    • Flip the Thinkpad on its side to get a better view of the hard drive.
    • Push on the lower edge of the hard drive cover to detach the hard drive from the Thinkpad.
    • Once you have detached the hard drive from the Thinkpad, slide the hard drive out of the device.
  4. IBM ThinkPad T30 Hard Drive Replacement: 4 단계, 이미지 1/2 IBM ThinkPad T30 Hard Drive Replacement: 4 단계, 이미지 2/2
    • Using the plastic tool, remove the black plastic cover from the main body of the hard drive.
    • Place the plastic tool at the ends of the plastic cover to detach it from the hard drive.
    • Once the black plastic has been detached, the plastic will then slide off the body of the hard drive.
  5. IBM ThinkPad T30 Hard Drive Replacement: 5 단계, 이미지 1/2 IBM ThinkPad T30 Hard Drive Replacement: 5 단계, 이미지 2/2
    • Remove the four 2.8 mm screws from the mounting bracket using a Phillips #0 screwdriver.
    • Pull the mounting bracket off of the hard drive.
    • It may be easier to remove the mounting bracket by rotating it off of the hard drive as if it is on a hinge.
결론
To reassemble your device with a new hard drive, follow these instructions in reverse order with a new hard drive replacing the old one.
다른 11명이 해당 안내서를 완성하였습니다.
Allie Knauer
회원 가입일: 10/05/12
90 평판
안내서 3개 작성하였습니다
Cal Poly, Team 3-20, Amido Fall 2012 Cal Poly, Team 3-20, Amido Fall 2012 회원
CPSU-AMIDO-F12S3G20
3 회원들
안내서 16개 작성하였습니다
댓글 한 개
good description and photos..thanks :]
David - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 12
30일 전: 60
전체 시간: 19,028
