이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Flip the ThinkPad upside down with the bottom facing you.
Slide the latch to the right into the unlock position.
While holding the latch in the unlock position, lift the battery out with your other hand.
Begin by removing the two black 16 mm Phillips #0 screws. The screws can be identified by the two notches next to each screw. One (marked in red) is near the battery lock and the other (not pictured) is next to the Wi-Fi cover.
Push up the bottom of the keyboard by poking your finger through the hole to the right of the yellow bios battery. You will feel slight resistance.
Lift the keyboard to expose the ribbon connector and lean it against the computer screen to keep the ribbon intact.
Use the plastic opening tool to gently pry the connector up from the motherboard.
You can now safely remove the keyboard.
Using the plastic opening tool, gently lift the white connector out of its socket on the motherboard.
Follow iFixit's guide for [잘못된 안내서 링크] for a detailed explanation.
To remove the processor, set the dial on the processor socket to unlock using a small screwdriver
Unscrew until processor looks like it "lifts" a little.
Gently lift up one side of the processor to unseat, then remove completely from device.
다른 4명이 해당 안내서를 완성하였습니다.
