주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
IBM ThinkPad T42 Fan Replacement
필요한 것
  1. IBM ThinkPad T42 Fan Replacement, Bottom cover: 1 단계, 이미지 1개 중 1개
    • Use a Phillips #0 screwdriver to remove the twenty screws on the underside of the T42.
  2. IBM ThinkPad T42 Fan Replacement, Rear screws: 2 단계, 이미지 1개 중 1개
    • Remove the four Phillips screws located on either side of the rear of the T42 (there are two on each end.)
  3. IBM ThinkPad T42 Fan Replacement, Keyboard and Trackpad: 3 단계, 이미지 1개 중 1개
    • Flip the laptop over and open the screen to access the keyboard and trackpad.
    • The keyboard and trackpad are connected to the motherboard. Before removing the keyboard and trackpad, disconnect both components from the motherboard, as shown in the following step.
    • The bezel and keyboard will be loose, be careful.
  4. IBM ThinkPad T42 Fan Replacement: 4 단계, 이미지 2개 중 1개 IBM ThinkPad T42 Fan Replacement: 4 단계, 이미지 2개 중 2개
    • Carefully maneuver the palm rest away from the keyboard, as both the keyboard and palm rest/trackpad will come off together.
    • Remember, both the keyboard and trackpad have connectors to the motherboard. Disconnect these before completely removing either component.
  5. IBM ThinkPad T42 Fan Replacement, Plastic Edge Cover: 5 단계, 이미지 2개 중 1개 IBM ThinkPad T42 Fan Replacement, Plastic Edge Cover: 5 단계, 이미지 2개 중 2개
    • Starting from the bottom right, carefully remove the bezel by pulling it up gently. If needed use a spudger or flathead screwdriver to help.
  6. IBM ThinkPad T42 Fan Replacement, Lower Bracket: 6 단계, 이미지 2개 중 1개 IBM ThinkPad T42 Fan Replacement, Lower Bracket: 6 단계, 이미지 2개 중 2개
    • Grasp the metal bracket to remove it from the device.
  7. IBM ThinkPad T42 Fan Replacement, Microphone cover: 7 단계, 이미지 1개 중 1개
    • Remove the rubber cover from the microphone.
  8. IBM ThinkPad T42 Fan Replacement, Fan Removal: 8 단계, 이미지 2개 중 1개 IBM ThinkPad T42 Fan Replacement, Fan Removal: 8 단계, 이미지 2개 중 2개
    • Using the Phillips #0 screwdriver, remove the three screws on the copper heatsink.
    • Separate the copper heatsink by pulling it upwards, in order to unplug the connector from the motherboard.
    • Due to the nature of old thermal paste, it might take some force to remove the heatsink.
결론
다른 8명이 해당 안내서를 완성하였습니다.
작성자
10다른 기여자 명과 함께
Kevin Rehm
회원 가입일: 04/19/10
472 평판
안내서 4개를 작성함
Cal Poly, Team 29-76, Johann Spring 2010 Cal Poly, Team 29-76, Johann Spring 2010 회원
CPSU-JOHANN-S10S29G76
4 회원들
안내서 37개를 작성함
2가이드 댓글
How about you just down the freely available Hardware Maintenance Manual (HMM) for the laptop. They are downloadable in PDF format, and very well done.
Martin Campbell - 답글
It doesnt take this much, if you remove the palm rest and keyboard you can get it at an angle it slides straight out.
Tobyn Genn - 답글
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 22
지난 30일: 71
전체 시간: 27,037
