주요 콘텐츠로 건너뛰기
IBM ThinkPad T42 Hard Drive Replacement
필요한 것
  1. IBM ThinkPad T42 Hard Drive Replacement, Battery Clips: 1 단계, 이미지 1/1
    • Flip the laptop over so the underside is facing you, then, release the 2 clips holding the battery on.
    • Make sure the laptop is off when you do this, sudden power outages can cause data corruption.
  2. IBM ThinkPad T42 Hard Drive Replacement, Removing the Battery: 2 단계, 이미지 1/1
    • Carefully grab the battery, then pull it straight out, not at an angle.
  3. IBM ThinkPad T42 Hard Drive Replacement, Hard Drive Screw: 3 단계, 이미지 1/1
    • Unscrew the single screw holding the drive cage in place.
  4. IBM ThinkPad T42 Hard Drive Replacement, Sliding Drive Out: 4 단계, 이미지 1/1
    • Pull the hard drive out with of its bay the help of pictured ridges. Carefully remove it.
    • It might help to open the display slightly.
  5. IBM ThinkPad T42 Hard Drive Replacement, Removal of HDD: 5 단계, 이미지 1/1
    • Pull the Hard Drive out and proceed with replacement.
결론
다른 7명이 해당 안내서를 완성하였습니다.
Austin Kidd
회원 가입일: 04/21/10
317 평판
안내서 3개 작성하였습니다
Cal Poly, Team 29-76, Johann Spring 2010 Cal Poly, Team 29-76, Johann Spring 2010 회원
CPSU-JOHANN-S10S29G76
4 회원들
안내서 35개 작성하였습니다
댓글 한 개
Excelente guía. Gracias
Luis Aguilar - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 20
30일 전: 89
전체 시간: 20,643
