주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
Replacing the Hard Drive
부품
지정된 부품이 없습니다.
  1. Flip the laptop over so the underside is facing you, then, release the 2 clips holding the battery on.
    • Flip the laptop over so the underside is facing you, then, release the 2 clips holding the battery on.
    • Make sure the laptop is off when you do this, sudden power outages can cause data corruption.
  2. Carefully grab the battery, then pull it straight out, not at an angle.
    • Carefully grab the battery, then pull it straight out, not at an angle.
  3. Unscrew the single screw holding the drive cage in place.
    • Unscrew the single screw holding the drive cage in place.
  4. Pull the hard drive out with of its bay the help of pictured ridges. Carefully remove it.
    • Pull the hard drive out with of its bay the help of pictured ridges. Carefully remove it.
    • It might help to open the display slightly.
  5. Pull the Hard Drive out and proceed with replacement.
    • Pull the Hard Drive out and proceed with replacement.
결론
다른 6명이 해당 안내서를 완성하였습니다.
Austin Kidd
회원 가입일: 2010년 04월 21일
254 평판
안내서 3개 작성하였습니다
Cal Poly, Team 29-76, Johann Spring 2010 Cal Poly, Team 29-76, Johann Spring 2010 회원
CPSU-JOHANN-S10S29G76
4 회원들
안내서 30개 작성하였습니다
Excelente guía. Gracias
Luis Aguilar - 답글
댓글 쓰기
조회 통계:
24 시간 전: 6
7일 전: 20
30일 전: 79
전체 시간: 17,082
