주요 콘텐츠로 건너뛰기
IBM ThinkPad T42 Mini-PCI Port Replacement
필요한 것
  1. IBM ThinkPad T42 Mini-PCI Port Replacement, Bottom cover: 1 단계, 이미지 1/1
    • Using a Phillips #0 screwdriver, identify and unscrew the twenty screws located on the underside of the T42.
  2. IBM ThinkPad T42 Mini-PCI Port Replacement, Rear screws: 2 단계, 이미지 1/1
    • Unscrew the four Phillips screws located on either side of the rear of the T42 (there are two located on each end.)
  3. IBM ThinkPad T42 Mini-PCI Port Replacement, Keyboard and Trackpad: 3 단계, 이미지 1/1
    • Flip the laptop over and open the screen to access the keyboard and trackpad.
    • The keyboard and trackpad are connected to the motherboard. Before removing the keyboard and trackpad, disconnect both components from the motherboard, as shown in the following step.
    • The bezel and keyboard will be loose, be careful.
  4. IBM ThinkPad T42 Mini-PCI Port Replacement: 4 단계, 이미지 1/2 IBM ThinkPad T42 Mini-PCI Port Replacement: 4 단계, 이미지 2/2
    • Carefully maneuver the palm rest away from the keyboard, as both the keyboard and palm rest/trackpad will come off together.
    • Remember, both the keyboard and trackpad have connectors to the motherboard. Disconnect these before completely removing either component.
  5. IBM ThinkPad T42 Mini-PCI Port Replacement, Port Bracket: 5 단계, 이미지 1/1
    • Remove the screw affixing the bracket down.
  6. IBM ThinkPad T42 Mini-PCI Port Replacement, Bracket Removal: 6 단계, 이미지 1/1
    • Lift the bracket up and out.
  7. IBM ThinkPad T42 Mini-PCI Port Replacement, Port Removal: 7 단계, 이미지 1/1
    • Carefully disconnect it from the motherboard and pull it out of the device.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Gerald Watanabe
회원 가입일: 04/14/10
279 평판
안내서 7개 작성하였습니다
Cal Poly, Team 29-76, Johann Spring 2010 Cal Poly, Team 29-76, Johann Spring 2010 회원
CPSU-JOHANN-S10S29G76
4 회원들
안내서 35개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 5
전체 시간: 4,396
