주요 콘텐츠로 건너뛰기
IBM ThinkPad T42 Modem Daughter Board Replacement
필요한 것
  1. IBM ThinkPad T42 Modem Daughter Board Replacement, Bottom cover: 1 단계, 이미지 1/1
    • Using a Phillips #0 screwdriver, identify and unscrew the twenty screws located on the underside of the T42.
  2. IBM ThinkPad T42 Modem Daughter Board Replacement, Rear screws: 2 단계, 이미지 1/1
    • Unscrew the four Phillips screws located on either side of the rear of the T42 (there are two located on each end.)
  3. IBM ThinkPad T42 Modem Daughter Board Replacement, Keyboard and Trackpad: 3 단계, 이미지 1/1
    • Flip the laptop over and open the screen to access the keyboard and trackpad.
    • The keyboard and trackpad are connected to the motherboard. Before removing the keyboard and trackpad, disconnect both components from the motherboard, as shown in the following step.
    • The bezel and keyboard will be loose, be careful.
  4. IBM ThinkPad T42 Modem Daughter Board Replacement: 4 단계, 이미지 1/2 IBM ThinkPad T42 Modem Daughter Board Replacement: 4 단계, 이미지 2/2
    • Carefully maneuver the palm rest away from the keyboard, as both the keyboard and palm rest/trackpad will come off together.
    • Remember, both the keyboard and trackpad have connectors to the motherboard. Disconnect these before completely removing either component.
  5. IBM ThinkPad T42 Modem Daughter Board Replacement, Plastic Edge Cover: 5 단계, 이미지 1/2 IBM ThinkPad T42 Modem Daughter Board Replacement, Plastic Edge Cover: 5 단계, 이미지 2/2
    • Starting from the bottom right, carefully pry off the bezel. Use a spudger or flathead screwdriver if assistance is needed.
  6. IBM ThinkPad T42 Modem Daughter Board Replacement, Lower Bracket: 6 단계, 이미지 1/2 IBM ThinkPad T42 Modem Daughter Board Replacement, Lower Bracket: 6 단계, 이미지 2/2
    • Grasp the metal bracket to remove it from the device.
  7. IBM ThinkPad T42 Modem Daughter Board Replacement, Microphone cover: 7 단계, 이미지 1/1
    • Remove the rubber cover from the microphone.
  8. IBM ThinkPad T42 Modem Daughter Board Replacement, Daughterboard Unscrewing: 8 단계, 이미지 1/1
    • Next, unscrew the 3 Phillips screws in red.
  9. IBM ThinkPad T42 Modem Daughter Board Replacement, Removing the Daughterboard: 9 단계, 이미지 1/1
    • The cables are routed through different components for organization, carefully disconnect them, unwrap them and pull the card free.
  10. IBM ThinkPad T42 Modem Daughter Board Replacement, Remove Bracket: 10 단계, 이미지 1/1
    • Lastly, remove the bracket sitting beneath it.
    • The end!
결론
다른 2명이 해당 안내서를 완성하였습니다.
Gerald Watanabe
회원 가입일: 04/14/10
279 평판
안내서 7개 작성하였습니다
Cal Poly, Team 29-76, Johann Spring 2010 Cal Poly, Team 29-76, Johann Spring 2010 회원
CPSU-JOHANN-S10S29G76
4 회원들
안내서 35개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 4,988
