주요 콘텐츠로 건너뛰기
IBM ThinkPad T42 Wi-Fi Card Replacement
필요한 것
  1. IBM ThinkPad T42 Wi-Fi Card Replacement, Bottom cover: 1 단계, 이미지 1/1
    • Using a Phillips #0 screwdriver, identify and unscrew the twenty screws located on the underside of the T42.
  2. IBM ThinkPad T42 Wi-Fi Card Replacement, Rear screws: 2 단계, 이미지 1/1
    • Unscrew the four Phillips screws located on either side of the rear of the T42 (there are two located on each end.)
    leave these four screws alone. No need to remove them.
    fredwb - 답글
    There are tiny numbers showing the lengths of the screws. 1-2-3-4 where 1 is the shortest.
    The dark red circles are not very easy to see. How about white ones?
    mattikaki - 답글
  3. IBM ThinkPad T42 Wi-Fi Card Replacement, Keyboard and Trackpad: 3 단계, 이미지 1/1
    • Flip the laptop over and open the screen to access the keyboard and trackpad.
    • The keyboard and trackpad are connected to the motherboard. Before removing the keyboard and trackpad, disconnect both components from the motherboard, as shown in the following step.
    • The bezel and keyboard will be loose, be careful.
  4. IBM ThinkPad T42 Wi-Fi Card Replacement: 4 단계, 이미지 1/2 IBM ThinkPad T42 Wi-Fi Card Replacement: 4 단계, 이미지 2/2
    • Carefully maneuver the palm rest away from the keyboard, as both the keyboard and palm rest/trackpad will come off together.
    • Remember, both the keyboard and trackpad have connectors to the motherboard. Disconnect these before completely removing either component.
  5. IBM ThinkPad T42 Wi-Fi Card Replacement, Wi-Fi Card: 5 단계, 이미지 1/1
    • To remove Wi-Fi card, first disconnect both display wires on the top right.
  6. IBM ThinkPad T42 Wi-Fi Card Replacement: 6 단계, 이미지 1/1
    • Then slide both of the metal pieces holding it down outwards, and it will pop up.
  7. IBM ThinkPad T42 Wi-Fi Card Replacement: 7 단계, 이미지 1/1
    • Carefully pull it out.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Kevin Rehm
회원 가입일: 04/19/10
472 평판
안내서 4개 작성하였습니다
Cal Poly, Team 29-76, Johann Spring 2010 Cal Poly, Team 29-76, Johann Spring 2010 회원
CPSU-JOHANN-S10S29G76
4 회원들
안내서 35개 작성하였습니다
댓글 한 개
Get the HMM for the laptop! On a few of these, I have had to just pull out the internal wi-fi card, and use a USB wi-fi adapter.
Martin Campbell - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 21
전체 시간: 13,734
