주요 콘텐츠로 건너뛰기
IBM ThinkPad T43 CD Drive Replacement
필요한 것
  1. IBM ThinkPad T43 CD Drive Replacement, CD Drive: 1 단계, 이미지 1/1
    • Start by having the right side of the laptop facing you.
    • The laptop can be open if you would like, but it can be done easier if it is closed.
  2. IBM ThinkPad T43 CD Drive Replacement: 2 단계, 이미지 1/1
    • Remove the screw to be able to use the CD drive unlock switch
  3. IBM ThinkPad T43 CD Drive Replacement: 3 단계, 이미지 1/1
    • Locate the switch on the right side of the CD Drive.
  4. IBM ThinkPad T43 CD Drive Replacement: 4 단계, 이미지 1/3 IBM ThinkPad T43 CD Drive Replacement: 4 단계, 이미지 2/3 IBM ThinkPad T43 CD Drive Replacement: 4 단계, 이미지 3/3
    • Place finger in between the switch and the bumper
    • Slide the switch to the right until the plastic tab ejects.
  5. IBM ThinkPad T43 CD Drive Replacement: 5 단계, 이미지 1/3 IBM ThinkPad T43 CD Drive Replacement: 5 단계, 이미지 2/3 IBM ThinkPad T43 CD Drive Replacement: 5 단계, 이미지 3/3
    • Place fingers on the plastic tab.
    • Pull on the tab until the CD Drive ejects.
    • The tab only comes out about an inch to inch and a half.
    • Do not try to pull the tab all the way out.
    • If after you have removed the CD Drive and the tab goes back in, it is alright. It does not affect the later process.
  6. IBM ThinkPad T43 CD Drive Replacement: 6 단계, 이미지 1/2 IBM ThinkPad T43 CD Drive Replacement: 6 단계, 이미지 2/2
    • Grab the end of the CD Drive and pulls straight out towards your body.
    • Be careful not to pull it out at an angle to not risk damage.
  7. IBM ThinkPad T43 CD Drive Replacement: 7 단계, 이미지 1/1
    • Now that you have successfully removed the CD Drive you can put in the new one.
    • Place the end of the new CD Drive in and slide in until it clicks.
    • If you are using slight force and it doesn't go in, it could be jammed. Just take it out and try again.
    • If you had not already, you can push back in the tab.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
aLiX pIeRRe
회원 가입일: 03/19/18
855 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team S6-G4, Bernier Spring 2018 UMass Dartmouth, Team S6-G4, Bernier Spring 2018 회원
UMASSD-BERNIER-S18S6G4
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 15
전체 시간: 889
