주요 콘텐츠로 건너뛰기
IBM ThinkPad T43 Screen Replacement
필요한 것
  1. IBM ThinkPad T43 Screen Replacement, Screen: 1 단계, 이미지 3개 중 1개 IBM ThinkPad T43 Screen Replacement, Screen: 1 단계, 이미지 3개 중 2개 IBM ThinkPad T43 Screen Replacement, Screen: 1 단계, 이미지 3개 중 3개
    • Locate the screws holding the screen cover in place.
    • There are 3 screws on the left side, 4 on the right, and 4 across the bottom of the screen.
  2. IBM ThinkPad T43 Screen Replacement: 2 단계, 이미지 3개 중 1개 IBM ThinkPad T43 Screen Replacement: 2 단계, 이미지 3개 중 2개 IBM ThinkPad T43 Screen Replacement: 2 단계, 이미지 3개 중 3개
    • Remove the covers by inserting plastic spudger in between the edge of the cover and laptop.
    • Remove screws by using the Phillips head #0
    • The covers are set in with an adhesive so they may pop off when removing them.
  3. IBM ThinkPad T43 Screen Replacement: 3 단계, 이미지 3개 중 1개 IBM ThinkPad T43 Screen Replacement: 3 단계, 이미지 3개 중 2개 IBM ThinkPad T43 Screen Replacement: 3 단계, 이미지 3개 중 3개
    • Insert the flat metal spudger into the edge of the screen cover and slowly pry open.
    • Slide the spudger along the edges and pry open to release the cover from the clips
    • While slide the spudger up the side of the cover, pinch the cover to help unhook the clips
    • Across the bottom of the screen there is an adhesive, so you will need to carefully pry of that part of the cover
  4. IBM ThinkPad T43 Screen Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the two screws located near the bottom middle of the screen
  5. IBM ThinkPad T43 Screen Replacement: 5 단계, 이미지 3개 중 1개 IBM ThinkPad T43 Screen Replacement: 5 단계, 이미지 3개 중 2개 IBM ThinkPad T43 Screen Replacement: 5 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Flip over the green rectangular shaped board
    • Disconnect the screen from the rectangular board using your fingers or tweezers
  6. IBM ThinkPad T43 Screen Replacement: 6 단계, 이미지 1개 중 1개
    • Using "Flat metal spudger" lift up the screen from the bottom slowly until you see the ribbon cable
    • Detach the ribbon cable before lifting completely the screen
    • Now you be able to remove the screen
    • Because of how the ribbon cable is connected, it may detach when you lift the screen up
  7. IBM ThinkPad T43 Screen Replacement: 7 단계, 이미지 3개 중 1개 IBM ThinkPad T43 Screen Replacement: 7 단계, 이미지 3개 중 2개 IBM ThinkPad T43 Screen Replacement: 7 단계, 이미지 3개 중 3개
    • To replace the screen follow the next set of steps
    • Using your fingers or tweezers, pull out the light by placing them on the sides and lifting up
    • Insert the wide plug on the ribbon cable into the new screen and place back into the laptop.
    • Now if you follow these steps in reverse order, you will be able to finish replacing the screen
결론
작성자
3다른 기여자 명과 함께
aLiX pIeRRe
회원 가입일: 03/19/18
855 평판
안내서 5개를 작성함
UMass Dartmouth, Team S6-G4, Bernier Spring 2018 UMass Dartmouth, Team S6-G4, Bernier Spring 2018 회원
UMASSD-BERNIER-S18S6G4
4 회원들
안내서 10개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 7
지난 7일: 17
지난 30일: 30
전체 시간: 1,476
