주요 콘텐츠로 건너뛰기
IBM ThinkPad X41 LCD Screen Replacement
필요한 것
  1. IBM ThinkPad X41 LCD Screen Replacement, LCD Screen: 1 단계, 이미지 3개 중 1개 IBM ThinkPad X41 LCD Screen Replacement, LCD Screen: 1 단계, 이미지 3개 중 2개 IBM ThinkPad X41 LCD Screen Replacement, LCD Screen: 1 단계, 이미지 3개 중 3개
    • Open the laptop and turn to the side.
    • Using the spudger, remove the 6 black rectangular-shaped screw coverings (3 on each side)
  2. IBM ThinkPad X41 LCD Screen Replacement: 2 단계, 이미지 1개 중 1개
    • Using a Phillips Screw Driver, remove the (6) Phillips Head (Size PH001) 3.0 mm length screws (3 on each side) from the side of the LCD Screen Cover
  3. IBM ThinkPad X41 LCD Screen Replacement: 3 단계, 이미지 2개 중 1개 IBM ThinkPad X41 LCD Screen Replacement: 3 단계, 이미지 2개 중 2개
    • Using the spudger, remove the two round, black screw coverings on the lower, left, and right corners of the LCD screen bezel.
  4. IBM ThinkPad X41 LCD Screen Replacement: 4 단계, 이미지 2개 중 1개 IBM ThinkPad X41 LCD Screen Replacement: 4 단계, 이미지 2개 중 2개
    • Using a Phillips Screwdriver (Size PH001), remove the 3.0 mm screws from the lower, left and right corners of the LCD screen Bezel
  5. IBM ThinkPad X41 LCD Screen Replacement: 5 단계, 이미지 2개 중 1개 IBM ThinkPad X41 LCD Screen Replacement: 5 단계, 이미지 2개 중 2개
    • Using 2 Fingers, pull the bottom of the screen bezel towards you.
    • Pull the bottom of the screen bezel approximately 1 inch away from the LCD screen.
    • Next, pull screen bezel downward and away from the LCD screen.
  6. IBM ThinkPad X41 LCD Screen Replacement: 6 단계, 이미지 1개 중 1개
    • Using your index finger and thumb, gently lift and pull away laptop closure latch of the side of the screen assembly.
  7. IBM ThinkPad X41 LCD Screen Replacement: 7 단계, 이미지 2개 중 1개 IBM ThinkPad X41 LCD Screen Replacement: 7 단계, 이미지 2개 중 2개
    • Use a Phillips head screwdriver to remove the internal LCD screen support assembly above the F6 key.
  8. IBM ThinkPad X41 LCD Screen Replacement: 8 단계, 이미지 3개 중 1개 IBM ThinkPad X41 LCD Screen Replacement: 8 단계, 이미지 3개 중 2개 IBM ThinkPad X41 LCD Screen Replacement: 8 단계, 이미지 3개 중 3개
    • Close the laptop and turn so that the laptop's backside is facing you.
    • Using a thumb and index finger, gently lift the LCD screen back cover away from laptop.
  9. IBM ThinkPad X41 LCD Screen Replacement: 9 단계, 이미지 3개 중 1개 IBM ThinkPad X41 LCD Screen Replacement: 9 단계, 이미지 3개 중 2개 IBM ThinkPad X41 LCD Screen Replacement: 9 단계, 이미지 3개 중 3개
    • Using a spudger, remove the black, rectangular support tape.
  10. IBM ThinkPad X41 LCD Screen Replacement: 10 단계, 이미지 2개 중 1개 IBM ThinkPad X41 LCD Screen Replacement: 10 단계, 이미지 2개 중 2개
    • Carefully disconnect the orange cable from back of LCD screen.
  11. IBM ThinkPad X41 LCD Screen Replacement: 11 단계, 이미지 2개 중 1개 IBM ThinkPad X41 LCD Screen Replacement: 11 단계, 이미지 2개 중 2개
    • Using a Phillips Screwdriver (Size PH001), remove the screws from the LCD screen support arms.
  12. IBM ThinkPad X41 LCD Screen Replacement: 12 단계, 이미지 2개 중 1개 IBM ThinkPad X41 LCD Screen Replacement: 12 단계, 이미지 2개 중 2개
    • Unplug the orange LCD screen cable from the small circuit board near the laptop keyboard.
  13. IBM ThinkPad X41 LCD Screen Replacement: 13 단계, 이미지 2개 중 1개 IBM ThinkPad X41 LCD Screen Replacement: 13 단계, 이미지 2개 중 2개
    • Using one hand, gently lift the LCD screen out of support arms.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Justin Macik
회원 가입일: 09/12/16
228 평판
안내서 1개를 작성함
CSU Fullerton, Team 2-4, Bruce Fall 2016 CSU Fullerton, Team 2-4, Bruce Fall 2016 회원
CSUF-BRUCE-F16S2G4
4 회원들
안내서 8개를 작성함
1가이드 댓글
nice little guide, short and too the point,
Vaughan Prendergast - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 5
지난 30일: 20
전체 시간: 1,661
