주요 콘텐츠로 건너뛰기
IBM ThinkPad t43 RAM Replacement
필요한 것
  1. IBM ThinkPad t43 RAM Replacement, RAM: 1 단계, 이미지 1/3 IBM ThinkPad t43 RAM Replacement, RAM: 1 단계, 이미지 2/3 IBM ThinkPad t43 RAM Replacement, RAM: 1 단계, 이미지 3/3
    • To remove the cover, you will need to take out the single screw.
    • Unscrew until the cover comes off
    • Lift the cover from the edge and pull off
    • If the cover doesn't come right up and you have felt that you have unscrewed it, you can lift the cover and the screw will come off with it.
  2. IBM ThinkPad t43 RAM Replacement: 2 단계, 이미지 1/3 IBM ThinkPad t43 RAM Replacement: 2 단계, 이미지 2/3 IBM ThinkPad t43 RAM Replacement: 2 단계, 이미지 3/3
    • Place your hands on the clips and push on them outward until the RAM pops out
  3. IBM ThinkPad t43 RAM Replacement: 3 단계, 이미지 1/2 IBM ThinkPad t43 RAM Replacement: 3 단계, 이미지 2/2
    • Place hands on the RAM and pull towards yourself
    • For replacement, follow these steps in reverse order
    • Make sure that when you put in the ram that the short side is on the right
결론
다른 2명이 해당 안내서를 완성하였습니다.
aLiX pIeRRe
회원 가입일: 03/19/18
855 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team S6-G4, Bernier Spring 2018 UMass Dartmouth, Team S6-G4, Bernier Spring 2018 회원
UMASSD-BERNIER-S18S6G4
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 24
전체 시간: 1,132
