주요 콘텐츠로 건너뛰기
IBM Thinkpad T60 Keyboard Replacement
필요한 것
  1. IBM Thinkpad T60 Keyboard Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Turn the computer over to see the small tab on the battery located near the top of the Thinkpad.
    • Use your finger to slide the tab to the right to unlock the battery.
  2. IBM Thinkpad T60 Keyboard Replacement: 2 단계, 이미지 2개 중 1개 IBM Thinkpad T60 Keyboard Replacement: 2 단계, 이미지 2개 중 2개
    • Once the tab is in the unlocked position (far right), pull the battery outwards away from the Thinkpad.
    • The battery is now disconnected.
  3. IBM Thinkpad T60 Keyboard Replacement, Palm Rest: 3 단계, 이미지 2개 중 1개 IBM Thinkpad T60 Keyboard Replacement, Palm Rest: 3 단계, 이미지 2개 중 2개
    • Using a #0 Phillips screwdriver, remove the four 17.0 mm screws.
  4. IBM Thinkpad T60 Keyboard Replacement: 4 단계, 이미지 1개 중 1개
    • Turn the computer back over, so the keyboard is facing upwards.
    • Open the display to access the palm rest. Apply pressure to the sides of the palm rest so that it bends upwards in the middle. Gently lift away from the computer.
  5. IBM Thinkpad T60 Keyboard Replacement: 5 단계, 이미지 2개 중 1개 IBM Thinkpad T60 Keyboard Replacement: 5 단계, 이미지 2개 중 2개
    • Slightly lift the palm rest away from the computer.
    • The touchpad's data cable connects the palm rest to the base unit. BE CAREFUL!
    • Detach the connector by pulling upwards on the white tab.
  6. IBM Thinkpad T60 Keyboard Replacement, Keyboard: 6 단계, 이미지 2개 중 1개 IBM Thinkpad T60 Keyboard Replacement, Keyboard: 6 단계, 이미지 2개 중 2개
    • Turn the Thinkpad over so you can see the bottom.
    • Using a #0 Phillips screwdriver, remove the 17.0 mm screw.
  7. IBM Thinkpad T60 Keyboard Replacement: 7 단계, 이미지 2개 중 1개 IBM Thinkpad T60 Keyboard Replacement: 7 단계, 이미지 2개 중 2개
    • First, flip the laptop back over. Next, use your fingers to pry the keyboard upwards slightly.
    • Lift the keyboard until you are able to see the wire connection
  8. IBM Thinkpad T60 Keyboard Replacement: 8 단계, 이미지 2개 중 1개 IBM Thinkpad T60 Keyboard Replacement: 8 단계, 이미지 2개 중 2개
    • Pull upwards on the connector to disconnect the keyboard.
    • The keyboard is now disconnected.
결론
다른 8명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Dylan Kratochvil
회원 가입일: 01/30/13
663 평판
안내서 3개를 작성함
Cal Poly, Team 7-9, Maness Winter 2013 Cal Poly, Team 7-9, Maness Winter 2013 회원
CPSU-MANESS-W13S7G9
4 회원들
안내서 16개를 작성함
1가이드 댓글
Die Anleitung war gut.
Müller, Christine - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 27
전체 시간: 5,347
