주요 콘텐츠로 건너뛰기
IBM Thinkpad T60 Palm Rest Replacement
필요한 것
  1. IBM Thinkpad T60 Palm Rest Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Turn the computer over to see the small tab on the battery located near the top of the Thinkpad.
    • Use your finger to slide the tab to the right to unlock the battery.
  2. IBM Thinkpad T60 Palm Rest Replacement: 2 단계, 이미지 2개 중 1개 IBM Thinkpad T60 Palm Rest Replacement: 2 단계, 이미지 2개 중 2개
    • Once the tab is in the unlocked position (far right), pull the battery outwards away from the Thinkpad.
    • The battery is now disconnected.
  3. IBM Thinkpad T60 Palm Rest Replacement, Palm Rest: 3 단계, 이미지 2개 중 1개 IBM Thinkpad T60 Palm Rest Replacement, Palm Rest: 3 단계, 이미지 2개 중 2개
    • Using a #0 Phillips screwdriver, remove the four 17.0 mm screws.
  4. IBM Thinkpad T60 Palm Rest Replacement: 4 단계, 이미지 1개 중 1개
    • Turn the computer back over, so the keyboard is facing upwards.
    • Open the display to access the palm rest. Apply pressure to the sides of the palm rest so that it bends upwards in the middle. Gently lift away from the computer.
  5. IBM Thinkpad T60 Palm Rest Replacement: 5 단계, 이미지 2개 중 1개 IBM Thinkpad T60 Palm Rest Replacement: 5 단계, 이미지 2개 중 2개
    • Slightly lift the palm rest away from the computer.
    • The touchpad's data cable connects the palm rest to the base unit. BE CAREFUL!
    • Detach the connector by pulling upwards on the white tab.
결론
다른 5명이 해당 안내서를 완성하였습니다.
작성자
12다른 기여자 명과 함께
Dylan Kratochvil
회원 가입일: 01/30/13
663 평판
안내서 3개를 작성함
Cal Poly, Team 7-9, Maness Winter 2013 Cal Poly, Team 7-9, Maness Winter 2013 회원
CPSU-MANESS-W13S7G9
4 회원들
안내서 16개를 작성함
1가이드 댓글
Needs a tutorial on how to install it. I can’t get the palmrest on correctly, I can still lift up on the palmrest and the laptop doesn’t latch properly.
Kyle Gilchrist - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 5
지난 30일: 18
전체 시간: 2,636
