메인 콘텐츠로 스킵하기
소개
If your computer has trouble reading discs and/or the disc drive is not working, it might need to be replaced. This guide will show you step by step how to replace the disc drive.
  1. Place the computer on its side so that the disc drive is facing up.
    • Place the computer on its side so that the disc drive is facing up.
    • Push in the release lever shown.
  2. Once the tab pops out, pull it away from the computer to release the disc drive.
    • Once the tab pops out, pull it away from the computer to release the disc drive.
  3. Pull the disc drive away from the laptop to fully remove it. Pull the disc drive away from the laptop to fully remove it.
    • Pull the disc drive away from the laptop to fully remove it.
  4. Insert new disk drive back into laptop
    • Insert new disk drive back into laptop
  5. Be sure to push the pull tab in as shown in the picture.
    • Be sure to push the pull tab in as shown in the picture.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Kyle
회원 가입일: 2013년 04월 18일
317 평판
안내서 4개 작성하였습니다
Cal Poly, Team 8-58, Johann Spring 2013 Cal Poly, Team 8-58, Johann Spring 2013 회원
CPSU-JOHANN-S13S8G58
4 회원들
안내서 10개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 9
전체 시간: 837
