주요 콘텐츠로 건너뛰기
IBM/Lenovo Thinkpad T61 Hard Drive Replacement
필요한 것
  1. IBM/Lenovo Thinkpad T61 Hard Drive Replacement, Hard Drive: 1 단계, 이미지 1/1
    • Turn the computer over so that the back is facing upwards.
    • Locate the screw in the bottom left-hand corner of the computer.
  2. IBM/Lenovo Thinkpad T61 Hard Drive Replacement: 2 단계, 이미지 1/1
    • Using a #0 Phillips screwdriver, remove the 17 mm screw.
  3. IBM/Lenovo Thinkpad T61 Hard Drive Replacement: 3 단계, 이미지 1/1
    • Carefully remove the plastic piece covering the hard drive by first pulling up then away from the computer.
  4. IBM/Lenovo Thinkpad T61 Hard Drive Replacement: 4 단계, 이미지 1/2 IBM/Lenovo Thinkpad T61 Hard Drive Replacement: 4 단계, 이미지 2/2
    • Locate the folded black tab within the hard drive port.
    • With a screwdriver, pull the black tab out of the slot.
  5. IBM/Lenovo Thinkpad T61 Hard Drive Replacement: 5 단계, 이미지 1/2 IBM/Lenovo Thinkpad T61 Hard Drive Replacement: 5 단계, 이미지 2/2
    • Pull gently on the black tab and the metal tray holding the hard drive will slide out.
  6. IBM/Lenovo Thinkpad T61 Hard Drive Replacement: 6 단계, 이미지 1/1
    • Remove the plastic coverings on both sides of the hard drive.
    • Note that there is no hard drive in this picture but the process will remain the same.
결론
To reassemble your device, follow these instructions in reverse order. If your pull tab is broken, you will need to find something to use as a pull tab for the new drive. You can get a long piece of tape, and fold the end and stick the rest to the drive.
다른 7명이 해당 안내서를 완성하였습니다.
Kyle
회원 가입일: 04/18/13
458 평판
안내서 4개 작성하였습니다
Cal Poly, Team 8-58, Johann Spring 2013 Cal Poly, Team 8-58, Johann Spring 2013 회원
CPSU-JOHANN-S13S8G58
4 회원들
안내서 10개 작성하였습니다
댓글 한 개
Ibm t61 caddy rail purchase
Afjal Ansari - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 17
30일 전: 50
전체 시간: 6,544
