메인 콘텐츠로 스킵하기
소개
This guide is for those who need to remove the keyboard, in order to replace or clean it.
  1. Ensure the laptop has been properly shut down and unplugged.
    • Ensure the laptop has been properly shut down and unplugged.
    • Turn the computer over so that you can see the battery release tab located near the top of the Thinkpad.
  2. Use your finger to slide the release tab to the unlocked symbol.
    • Use your finger to slide the release tab to the unlocked symbol.
  3. Hold the tab in the unlocked position and push the battery away from the computer to remove it. Hold the tab in the unlocked position and push the battery away from the computer to remove it. Hold the tab in the unlocked position and push the battery away from the computer to remove it.
    • Hold the tab in the unlocked position and push the battery away from the computer to remove it.
  4. Slide the new battery in until it clicks.
    • Slide the new battery in until it clicks.
    • Ensure that the release tab is in the locked position.
  5. Use the PH1 bit screwdriver, remove five 17.0mm screws on the back of the computer.
    • Use the PH1 bit screwdriver, remove five 17.0mm screws on the back of the computer.
    • These screws have a keyboard symbol next to them.
    • Make sure you keep the screws together and do not misplace any of them
  6. 아이폰 배터리 수리 키트
    Only $29.99
    Buy Now
    아이폰 배터리 수리 키트
    Only $29.99
    Buy Now
  7. Turn the computer over so the keyboard is facing upwards, and open the Thinkpad.
    • Turn the computer over so the keyboard is facing upwards, and open the Thinkpad.
    • Release the panel by lifting up on the outside edges just below the keyboard.
  8. Gently pull the panel away from the computer. BE CAREFUL! The panel is still attached by the touchpad's data cable.
    • Gently pull the panel away from the computer.
    • BE CAREFUL! The panel is still attached by the touchpad's data cable.
    • Detach the connecter by pulling up on the white tab.
  9. Using your fingers, lift the front edge of the keyboard until you can see the wire connecting it. Using your fingers, lift the front edge of the keyboard until you can see the wire connecting it.
    • Using your fingers, lift the front edge of the keyboard until you can see the wire connecting it.
  10. Gently pull up on the connecter to disconnect the keyboard.
    • Gently pull up on the connecter to disconnect the keyboard.
    • The keyboard will no longer be attached and can now be fully removed.
    • Take the replacement keyboard and push the new connector tab back into place.
  11. Line up keyboard and place back into the position, make sure it is lined up with the back first. Lower the rest of the keyboard back into place so it lies flat against the computer's shell.
    • Line up keyboard and place back into the position, make sure it is lined up with the back first.
    • Lower the rest of the keyboard back into place so it lies flat against the computer's shell.
  12. Push in white tab to reconnect the touch pad panel. Push in white tab to reconnect the touch pad panel.
    • Push in white tab to reconnect the touch pad panel.
  13. Push in touch pad panel back into place by lining it up starting from the bottom and pushing it down until it fits back into place. Push in touch pad panel back into place by lining it up starting from the bottom and pushing it down until it fits back into place.
    • Push in touch pad panel back into place by lining it up starting from the bottom and pushing it down until it fits back into place.
  14. Close laptop.
    • Close laptop.
  15. Flip the laptop over so that the side with the screws is facing up.
    • Flip the laptop over so that the side with the screws is facing up.
    • Put back all the screws, make sure they are in tightly.
    • The new keyboard is now in securely.
결론
Once these steps are completed, the keyboard will be fully replaced.
다른 6명이 해당 안내서를 완성하였습니다.
Michael Chapiro
회원 가입일: 2013년 04월 18일
1 평판
안내서 1개 작성함
Cal Poly, Team 8-58, Johann Spring 2013 Cal Poly, Team 8-58, Johann Spring 2013 회원
CPSU-JOHANN-S13S8G58
4 회원들
안내서 10개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 7
전체 시간: 2,172
