주요 콘텐츠로 건너뛰기
IBM Thinkpad T61 Trackpad Replacement
필요한 것
  1. IBM Thinkpad T61 Trackpad Replacement, Trackpad: 1 단계, 이미지 1/1
    • Flip your computer over and remove the four indicated screws with the Phillips #1 screwdriver.
  2. IBM Thinkpad T61 Trackpad Replacement: 2 단계, 이미지 1/1
    • With the screws removed, the trackpad panel should lift as shown. Gently lift so the inside is visible.
  3. IBM Thinkpad T61 Trackpad Replacement: 3 단계, 이미지 1/2 IBM Thinkpad T61 Trackpad Replacement: 3 단계, 이미지 2/2
    • Gently remove the white plug to disconnect the trackpad panel from the bottom of the computer.
    • Use the screwdriver to remove the four screws from the trackpad. Two of the screws are located just under the plastic.
  4. IBM Thinkpad T61 Trackpad Replacement: 4 단계, 이미지 1/3 IBM Thinkpad T61 Trackpad Replacement: 4 단계, 이미지 2/3 IBM Thinkpad T61 Trackpad Replacement: 4 단계, 이미지 3/3
    • Separate the trackpad with the bottom mouse buttons from the trackpad panel.
  5. IBM Thinkpad T61 Trackpad Replacement: 5 단계, 이미지 1/1
    • Align the new trackpad so the screw holes line up with their insertion points. Replace the screws with the screwdriver.
  6. IBM Thinkpad T61 Trackpad Replacement: 6 단계, 이미지 1/1
    • Reinsert the white plug.
  7. IBM Thinkpad T61 Trackpad Replacement: 7 단계, 이미지 1/2 IBM Thinkpad T61 Trackpad Replacement: 7 단계, 이미지 2/2
    • Replace the trackpad panel.
    • Use the screwdriver to replace the screws, refastening the trackpad panel to the computer.
결론
Replace the battery and plug in your computer. Test out your new trackpad!
다른 6명이 해당 안내서를 완성하였습니다.
Raymond Lawton
회원 가입일: 03/12/14
245 평판
안내서 1개 작성함
UMass Dartmouth, Team 6-6, Vijaybhaskar Spring 2014 UMass Dartmouth, Team 6-6, Vijaybhaskar Spring 2014 회원
UMASSD-VIJAYBHASKAR-S14S6G6
3 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 15
전체 시간: 1,774
