주요 콘텐츠로 건너뛰기
Ibanez 5 String Bass Model SR405QM Output Jack Replacement
필요한 것
  1. Ibanez 5 String Bass Model SR405QM Output Jack Replacement, Battery: 1 단계, 이미지 1/1
    • Gently place the instrument upside-down on a soft surface.
    • Locate the battery cavity cap and screws.
  2. Ibanez 5 String Bass Model SR405QM Output Jack Replacement: 2 단계, 이미지 1/1
    • Use a Phillips #2 head screwdriver to unscrew both screws. Two #1 1mm long screws.
  3. Ibanez 5 String Bass Model SR405QM Output Jack Replacement: 3 단계, 이미지 1/2 Ibanez 5 String Bass Model SR405QM Output Jack Replacement: 3 단계, 이미지 2/2
    • Remove the cap by lifting upwards to reveal the battery.
  4. Ibanez 5 String Bass Model SR405QM Output Jack Replacement: 4 단계, 이미지 1/3 Ibanez 5 String Bass Model SR405QM Output Jack Replacement: 4 단계, 이미지 2/3 Ibanez 5 String Bass Model SR405QM Output Jack Replacement: 4 단계, 이미지 3/3
    • Gently lift the battery from the cavity.
    • Detach the battery completely by firmly pulling the fabric connector from the conducting end of the battery.
  5. Ibanez 5 String Bass Model SR405QM Output Jack Replacement, Backplate: 5 단계, 이미지 1/2 Ibanez 5 String Bass Model SR405QM Output Jack Replacement, Backplate: 5 단계, 이미지 2/2
    • Use a Phillips #2 screwdriver to remove the four screws on the backplate.
  6. Ibanez 5 String Bass Model SR405QM Output Jack Replacement: 6 단계, 이미지 1/2 Ibanez 5 String Bass Model SR405QM Output Jack Replacement: 6 단계, 이미지 2/2
    • Remove the cap by lifting upwards, revealing the circuitry of the instrument.
  7. Ibanez 5 String Bass Model SR405QM Output Jack Replacement, Output Jack: 7 단계, 이미지 1/3 Ibanez 5 String Bass Model SR405QM Output Jack Replacement, Output Jack: 7 단계, 이미지 2/3 Ibanez 5 String Bass Model SR405QM Output Jack Replacement, Output Jack: 7 단계, 이미지 3/3
    • Lift the green printed circuit board to move some of the wires.
    • Locate the output jack at the base of the cavity.
    • Move wires away from the end of the output jack to expose the three pins.
  8. Ibanez 5 String Bass Model SR405QM Output Jack Replacement: 8 단계, 이미지 1/2 Ibanez 5 String Bass Model SR405QM Output Jack Replacement: 8 단계, 이미지 2/2
    • Locate the gold nut at the base of the output Jack.
    • Do not remove the nut completely, but leave it about halfway down the output jack. We only want to move the prongs slightly away from all of the wires to allow for easier soldering.
    • Use the wrench to loosen the nut.
  9. Ibanez 5 String Bass Model SR405QM Output Jack Replacement: 9 단계, 이미지 1/3 Ibanez 5 String Bass Model SR405QM Output Jack Replacement: 9 단계, 이미지 2/3 Ibanez 5 String Bass Model SR405QM Output Jack Replacement: 9 단계, 이미지 3/3
    • Use a soldering iron to remove the three wires (two black, one white) from the output jack.
    • The soldering iron is extremely hot. Avoid contact with skin, fabric or the body of the instrument. When soldering iron is not in use, rest it on the soldering iron stand.
  10. Ibanez 5 String Bass Model SR405QM Output Jack Replacement: 10 단계, 이미지 1/3 Ibanez 5 String Bass Model SR405QM Output Jack Replacement: 10 단계, 이미지 2/3 Ibanez 5 String Bass Model SR405QM Output Jack Replacement: 10 단계, 이미지 3/3
    • Remove the loosened nut completely by rotating it counter-clockwise.
  11. Ibanez 5 String Bass Model SR405QM Output Jack Replacement: 11 단계, 이미지 1/3 Ibanez 5 String Bass Model SR405QM Output Jack Replacement: 11 단계, 이미지 2/3 Ibanez 5 String Bass Model SR405QM Output Jack Replacement: 11 단계, 이미지 3/3
    • Flip the bass over.
    • Remove output jack by pushing it gently from the back of the instrument and pulling it out from the front.
    • Insert a new output jack and tighten the nut about halfway.
  12. Ibanez 5 String Bass Model SR405QM Output Jack Replacement: 12 단계, 이미지 1/1
    • Use the soldering iron to attach the wires on to the new output jack according to the wiring diagram.
    • Securely tighten the nut using the adjustable wrench.
결론
To reassemble your device, follow steps 1-7 in reverse order.
다른 4명이 해당 안내서를 완성하였습니다.
Chris Pittner
회원 가입일: 01/11/13
220 평판
안내서 7개 작성하였습니다
Cal Poly, Team 5-18, Forte Winter 2013 Cal Poly, Team 5-18, Forte Winter 2013 회원
CPSU-FORTE-W13S5G18
4 회원들
안내서 9개 작성하였습니다
댓글 한 개
Thanks for the good, clear instructions. Well done, very helpful.
m10, Socorro NM
Clifton - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 36
전체 시간: 10,508
