주요 콘텐츠로 건너뛰기
Ibanez Bass Guitar String Replacement
필요한 것
  1. Ibanez Bass Guitar String Replacement, String: 1 단계, 이미지 1/2 Ibanez Bass Guitar String Replacement, String: 1 단계, 이미지 2/2
    • In this picture you will find the headstock of the bass.
    • Turning the tuning peg counter clockwise to loosen the string.
    • Here you may use a drill as an easy and fast alternative.
  2. Ibanez Bass Guitar String Replacement: 2 단계, 이미지 1/2 Ibanez Bass Guitar String Replacement: 2 단계, 이미지 2/2
    • Pull the string from the bottom of the bass from the guitar's bridge.
  3. Ibanez Bass Guitar String Replacement: 3 단계, 이미지 1/2 Ibanez Bass Guitar String Replacement: 3 단계, 이미지 2/2
    • Pull the string through the guitar's bridge and upward though the headstock of the guitar.
  4. Ibanez Bass Guitar String Replacement: 4 단계, 이미지 1/2 Ibanez Bass Guitar String Replacement: 4 단계, 이미지 2/2
    • Wrap the new string around the corresponding tuning peg.
  5. Ibanez Bass Guitar String Replacement: 5 단계, 이미지 1/2 Ibanez Bass Guitar String Replacement: 5 단계, 이미지 2/2
    • Tighten the string by turning the tuning peg.
  6. Ibanez Bass Guitar String Replacement: 6 단계, 이미지 1/2 Ibanez Bass Guitar String Replacement: 6 단계, 이미지 2/2
    • Repeat steps 2 through 5 until you have changed all four strings.
결론
After you remove the first string, you will reassemble and continue the process until you have changed all four strings.
Taylor Bonner
회원 가입일: 09/15/23
133 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 7
30일 전: 41
전체 시간: 233
