주요 콘텐츠로 건너뛰기
Ibanez Overdrive Battery Replacement
필요한 것
  1. Ibanez Overdrive Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Before replacing the battery, ensure the stompbox is turned off and disconnected from the power supply.
    • The red LED top of the potentiometer means the stompbox is on. No light from LED means the stompbox is off.
  2. Ibanez Overdrive Battery Replacement: 2 단계, 이미지 1/3 Ibanez Overdrive Battery Replacement: 2 단계, 이미지 2/3 Ibanez Overdrive Battery Replacement: 2 단계, 이미지 3/3
    • Verify the stompbox is off, before doing any repairs.
    • Rotate the stompbox onto its back. There will be four screws. Using a 1/4 Phillip screwdriver, remove all four screws from the back plate.
    • Remove all four screws by turning them counterclockwise.
  3. Ibanez Overdrive Battery Replacement: 3 단계, 이미지 1/3 Ibanez Overdrive Battery Replacement: 3 단계, 이미지 2/3 Ibanez Overdrive Battery Replacement: 3 단계, 이미지 3/3
    • Remove the back plate of the stompbox by lifting the backplate upwards.
    • Next, locate the 9-volt battery, which should be at the bottom of the overdrive stompbox, and carefully pull apart the battery from the battery clip connector.
  4. Ibanez Overdrive Battery Replacement: 4 단계, 이미지 1/3 Ibanez Overdrive Battery Replacement: 4 단계, 이미지 2/3 Ibanez Overdrive Battery Replacement: 4 단계, 이미지 3/3
    • After removing the depleted battery, insert a new 9-volt battery. Ensure the battery and battery clip connector are connected as shown in the photo.
    • After connecting the battery and battery clip connector, carefully reposition both items to their original position, as shown in the photo.
  5. Ibanez Overdrive Battery Replacement: 5 단계, 이미지 1/3 Ibanez Overdrive Battery Replacement: 5 단계, 이미지 2/3 Ibanez Overdrive Battery Replacement: 5 단계, 이미지 3/3
    • Once the battery is positioned at its original position, reattach the back plate.
    • Using a 1/4 Phillip screwdriver, re-screw all four screws onto the back plate.
    • Reattach all four screws by turning them clockwise.
결승점
Juan Colon
회원 가입일: 03/20/24
121 평판
안내서 1개 작성함
CSU Los Angeles, Team 1-1, Harris Spring 2024 CSU Los Angeles, Team 1-1, Harris Spring 2024 회원
CSULA-HARRIS-S24S1G1
3 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 4
전체 시간: 104
