주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
IdeaPad L340-15API RAM Replacement
필요한 것
  1. IdeaPad L340-15API RAM Replacement, Optical Drive: 1 단계, 이미지 2개 중 1개 IdeaPad L340-15API RAM Replacement, Optical Drive: 1 단계, 이미지 2개 중 2개
    • Before beginning the repair, make sure that the device is fully powered off.
    • Turn the laptop over so the bottom cover is facing up.
    • The small screw hole near the center of the case, marked with a tiny DVD icon and an arrow, secures the optical drive.
    댓글 쓰기
  2. IdeaPad L340-15API RAM Replacement: 2 단계, 이미지 2개 중 1개 IdeaPad L340-15API RAM Replacement: 2 단계, 이미지 2개 중 2개
    • Use a Phillips #1 screwdriver to remove the 7.5 mm screw securing the optical drive.
    • Place the screw down safely in a container/magnet strip where it will not get lost while you are working. These screws are very small and easily misplaced.
    댓글 쓰기
  3. IdeaPad L340-15API RAM Replacement: 3 단계, 이미지 2개 중 1개 IdeaPad L340-15API RAM Replacement: 3 단계, 이미지 2개 중 2개
    • Place your thumb at the seam between the optical drive and the device.
    • Gently pull the component straight out from the device, taking care not to pull at an angle.
    댓글 쓰기
  4. IdeaPad L340-15API RAM Replacement, Battery: 4 단계, 이미지 2개 중 1개 IdeaPad L340-15API RAM Replacement, Battery: 4 단계, 이미지 2개 중 2개
    • Use a Phillips #1 screwdriver to remove the twelve 7.5 mm screws from the back cover.
    댓글 쓰기
  5. IdeaPad L340-15API RAM Replacement: 5 단계, 이미지 3개 중 1개 IdeaPad L340-15API RAM Replacement: 5 단계, 이미지 3개 중 2개 IdeaPad L340-15API RAM Replacement: 5 단계, 이미지 3개 중 3개
    • Insert a plastic opening pick in the back left corner and wedge the panel open.
    • Slide the pick around the edge of the laptop to release the clips as you lift the panel.
    • If the opening pick isn’t working, use the iFixit opening tool to gain more leverage.
    • Remove the bottom cover.
    댓글 쓰기
  6. IdeaPad L340-15API RAM Replacement: 6 단계, 이미지 2개 중 1개 IdeaPad L340-15API RAM Replacement: 6 단계, 이미지 2개 중 2개
    • Use the Phillips #1 screwdriver to remove the five 6.5 mm screws securing the battery.
    • Use a container/magnet strip to store the screws while working.
    댓글 쓰기
  7. IdeaPad L340-15API RAM Replacement: 7 단계, 이미지 3개 중 1개 IdeaPad L340-15API RAM Replacement: 7 단계, 이미지 3개 중 2개 IdeaPad L340-15API RAM Replacement: 7 단계, 이미지 3개 중 3개
    • Use the wide end of a spudger to push the connector tab, sliding the battery connector out of its socket.
    • It may take a lot of force to disconnect the cable. Go slowly, and don't pull on the cables.
    댓글 쓰기
  8. IdeaPad L340-15API RAM Replacement: 8 단계, 이미지 1개 중 1개
    • Remove the battery from the laptop.
    댓글 쓰기
  9. IdeaPad L340-15API RAM Replacement, RAM: 9 단계, 이미지 3개 중 1개 IdeaPad L340-15API RAM Replacement, RAM: 9 단계, 이미지 3개 중 2개 IdeaPad L340-15API RAM Replacement, RAM: 9 단계, 이미지 3개 중 3개
    • Lift the metal cover next to the heat sink to reveal the RAM.
    댓글 쓰기
  10. IdeaPad L340-15API RAM Replacement: 10 단계, 이미지 3개 중 1개 IdeaPad L340-15API RAM Replacement: 10 단계, 이미지 3개 중 2개 IdeaPad L340-15API RAM Replacement: 10 단계, 이미지 3개 중 3개
    • Using your fingers or a spudger, spread the clips away from the RAM module.
    • Be careful not to pull too hard and damage the metal arms.
    • When released, the RAM module will pop up at a slight angle.
    • Lift the RAM module to an angle of about 30 degrees and slide it out.
    • When handling the RAM module, only touch the outside edges. Take care not to touch the gold-colored contact points along the bottom edge.
    • To install a new RAM module, insert it at about the same angle until it fits securely, then gently press it downward until the clips click into place.
    댓글 쓰기
결론
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Jasmyn
회원 가입일: 10/16/25
205 평판
안내서 2개를 작성함
UMass Dartmouth, Team 2-5, Bowman Fall 2025 UMass Dartmouth, Team 2-5, Bowman Fall 2025 회원
UMASSD-BOWMAN-F25S2G5
4 회원들
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 5
지난 30일: 24
전체 시간: 185
