주요 콘텐츠로 건너뛰기
IdeaPad Yoga 13 Charging Port Replacement
필요한 것
  1. IdeaPad Yoga 13 Charging Port Replacement, Charging Port: 1 단계, 이미지 1/1
    • Remove all ten screws using the T4 Torx screwdriver.
    • Remove the back cover from the device.
  2. IdeaPad Yoga 13 Charging Port Replacement: 2 단계, 이미지 1/2 IdeaPad Yoga 13 Charging Port Replacement: 2 단계, 이미지 2/2
    • Use the blue opening tool to further separate the keyboard bezel.
    • Carefully apply pressure to the keyboard. It should easily pop out.
  3. IdeaPad Yoga 13 Charging Port Replacement: 3 단계, 이미지 1/1
    • To remove the keyboard bezel, unscrew and remove the five screws using the Phillips #0 screwdriver.
  4. IdeaPad Yoga 13 Charging Port Replacement: 4 단계, 이미지 1/2 IdeaPad Yoga 13 Charging Port Replacement: 4 단계, 이미지 2/2
    • Unplug the connections from the motherboard.
    • There is a different connection for the mouse and keyboard.
  5. IdeaPad Yoga 13 Charging Port Replacement: 5 단계, 이미지 1/1
    • Remove the outer bezel to reveal the entire internal layout of the computer.
    • Motherboard and other internal components are now exposed.
  6. IdeaPad Yoga 13 Charging Port Replacement: 6 단계, 이미지 1/3 IdeaPad Yoga 13 Charging Port Replacement: 6 단계, 이미지 2/3 IdeaPad Yoga 13 Charging Port Replacement: 6 단계, 이미지 3/3
    • Remove charging port by prying out the yellow port from the computer chassis.
    • Note the route of the cable for re-installation of the replacement.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Kaitlyn Johnson
회원 가입일: 04/01/19
157 평판
안내서 1개 작성함
IUPUI, Team S1-G2, Harley Spring 2019 IUPUI, Team S1-G2, Harley Spring 2019 회원
IUPUI-HARLEY-S19S1G2
3 회원들
안내서 2개 작성하였습니다
댓글 한 개
do you have the schematic of the board?
Jorge Herrera - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 22
전체 시간: 1,625
