소개
You may find yourself in need of additional memory to feed hungry computer applications such as graphics and video editing tools. If you would like to replace a faulty RAM stick or one with insufficient capacity, follow this guide.
The battery for this device is not easily accessible and will require opening the device. Before you begin your replacement, be sure to disconnect the laptop from any power source. Additionally, we recommend that you turn off the device wait 5 minutes.
If you live in area rich of Static Electricity please advise using an ESD Strap.
필요한 것
Please turn off the device before opening the device
Remove the ten screws as shown in picture
The four bottom screws are different length for the other screws! (Blue Circle)
Remove the bottom case using a guitar pick
Remove the cable buy pushing the connector using the spudger (Red Circle)
Remove the Memory protective by using a pry tool (yellow rectangle)
After removing the memory protective push the silver tabs using a spudger (blue rectangle)
Remove the memory module.
Insert the new module according to the pin array
Push gently on the module until the two tabs are locked. (Locking the module)
다른 한 분이 해당 안내서를 완성하였습니다.
