주요 콘텐츠로 건너뛰기
Ikea Hektar Lamp Foot Pedal Switch Button Replacement
필요한 것
  1. Ikea Hektar Lamp Foot Pedal Switch Button Replacement, Foot Pedal Lamp Switch Button: 1 단계, 이미지 2개 중 1개 Ikea Hektar Lamp Foot Pedal Switch Button Replacement, Foot Pedal Lamp Switch Button: 1 단계, 이미지 2개 중 2개
    • Unplug the lamp from the power source.
    • Do not touch the metal prongs sticking out of the connector, only hold by the plastic section of the chord.
    • Find a well-lit area to work in and begin your repair.
  2. Ikea Hektar Lamp Foot Pedal Switch Button Replacement: 2 단계, 이미지 3개 중 1개 Ikea Hektar Lamp Foot Pedal Switch Button Replacement: 2 단계, 이미지 3개 중 2개 Ikea Hektar Lamp Foot Pedal Switch Button Replacement: 2 단계, 이미지 3개 중 3개
    • Flip the lamp switch upside down.
    • Use a Phillips #0 screwdriver to remove the four 6 mm screws from the bottom of the foot pedal while holding the button cap in place.
  3. Ikea Hektar Lamp Foot Pedal Switch Button Replacement: 3 단계, 이미지 2개 중 1개 Ikea Hektar Lamp Foot Pedal Switch Button Replacement: 3 단계, 이미지 2개 중 2개
    • Lift the top off of the foot pedal that holds the button in place and put it to the side.
    • Remove the damaged button from the switch and place it to the side.
  4. Ikea Hektar Lamp Foot Pedal Switch Button Replacement: 4 단계, 이미지 1개 중 1개
    • Briefly inspect the spring and electrical wiring for any visual damage.
    • If no internal damage is visible, continue to the next step.
  5. Ikea Hektar Lamp Foot Pedal Switch Button Replacement: 5 단계, 이미지 2개 중 1개 Ikea Hektar Lamp Foot Pedal Switch Button Replacement: 5 단계, 이미지 2개 중 2개
    • Replace the button and top of the foot pedal.
    • The button must be replaced before the cap to be held in place.
  6. Ikea Hektar Lamp Foot Pedal Switch Button Replacement: 6 단계, 이미지 3개 중 1개 Ikea Hektar Lamp Foot Pedal Switch Button Replacement: 6 단계, 이미지 3개 중 2개 Ikea Hektar Lamp Foot Pedal Switch Button Replacement: 6 단계, 이미지 3개 중 3개
    • Flip the pedal switch upside down.
    • Use a Phillips #0 screwdriver to replace the four 6 mm screws on the back while holding the switch together.
  7. Ikea Hektar Lamp Foot Pedal Switch Button Replacement: 7 단계, 이미지 2개 중 1개 Ikea Hektar Lamp Foot Pedal Switch Button Replacement: 7 단계, 이미지 2개 중 2개
    • Inspect the switch for any gaps around the edge.
    • Press down on the button to make sure you hear and/or feel a click.
  8. Ikea Hektar Lamp Foot Pedal Switch Button Replacement: 8 단계, 이미지 1개 중 1개
    • All done! Now you have a fully functional foot pedal lamp switch.
결론
작성자
1다른 기여자 명과 함께
Jesus Ortiz
회원 가입일: 03/15/24
157 평판
안내서 1개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 13
지난 30일: 62
전체 시간: 459
