주요 콘텐츠로 건너뛰기
Ikea RESGODS Bed Tray Leg Replacement
필요한 것
  1. Ikea RESGODS Bed Tray Leg Replacement, Ikea RESGODS Bed Tray Leg Replacement: 1 단계, 이미지 1/2 Ikea RESGODS Bed Tray Leg Replacement, Ikea RESGODS Bed Tray Leg Replacement: 1 단계, 이미지 2/2
    • Carefully place the bed tray face down on an even surface.
    • Avoid working on a table or surface that you wouldn't want to get scratched. While the repair is safe, you could inadvertently scratch the tabletop.
  2. Ikea RESGODS Bed Tray Leg Replacement: 2 단계, 이미지 1/2 Ikea RESGODS Bed Tray Leg Replacement: 2 단계, 이미지 2/2
    • Identify which screw is loose or which leg is detached.
    • Lift the bed tray leg by two millimeters.
  3. Ikea RESGODS Bed Tray Leg Replacement: 3 단계, 이미지 1/3 Ikea RESGODS Bed Tray Leg Replacement: 3 단계, 이미지 2/3 Ikea RESGODS Bed Tray Leg Replacement: 3 단계, 이미지 3/3
    • Insert the 1/2 inch truss head screw inside the leg hole.
  4. Ikea RESGODS Bed Tray Leg Replacement: 4 단계, 이미지 1/3 Ikea RESGODS Bed Tray Leg Replacement: 4 단계, 이미지 2/3 Ikea RESGODS Bed Tray Leg Replacement: 4 단계, 이미지 3/3
    • Slide two steel flat washers onto the screw.
  5. Ikea RESGODS Bed Tray Leg Replacement: 5 단계, 이미지 1/3 Ikea RESGODS Bed Tray Leg Replacement: 5 단계, 이미지 2/3 Ikea RESGODS Bed Tray Leg Replacement: 5 단계, 이미지 3/3
    • Attach the leg to the hole with the screw and steel flat washers.
  6. Ikea RESGODS Bed Tray Leg Replacement: 6 단계, 이미지 1/3 Ikea RESGODS Bed Tray Leg Replacement: 6 단계, 이미지 2/3 Ikea RESGODS Bed Tray Leg Replacement: 6 단계, 이미지 3/3
    • Use a Phillips #00 screwdriver to secure the screw to the tray.
결론
In conclusion, this guide is generally easy. You will just need the right screws and steel flat washer to fix it.
다른 한 분이 해당 안내서를 완성하였습니다.
Erik Francisco
회원 가입일: 01/12/24
133 평판
안내서 1개 작성함
York University, Team 2-10, O'Regan Winter 2024 York University, Team 2-10, O'Regan Winter 2024 회원
YORK-O'REGAN-W24S2G10
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 31
전체 시간: 206
