주요 콘텐츠로 건너뛰기
Imation Superdisk USB Drive Metal Casing Replacement
필요한 것
  1. Imation Superdisk USB Drive Metal Casing Replacement, Plastic Housing: 1 단계, 이미지 2개 중 1개 Imation Superdisk USB Drive Metal Casing Replacement, Plastic Housing: 1 단계, 이미지 2개 중 2개
    • Flip the device over so the bottom is facing up.
    • You will know it is the bottom because there will be six silver screws visible.
  2. Imation Superdisk USB Drive Metal Casing Replacement: 2 단계, 이미지 2개 중 1개 Imation Superdisk USB Drive Metal Casing Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the USB converter device by gently pulling it out.
    • Do not pull the converter device out by the cord.
  3. Imation Superdisk USB Drive Metal Casing Replacement: 3 단계, 이미지 2개 중 1개 Imation Superdisk USB Drive Metal Casing Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the six silver screws using a small Phillips head screwdriver.
  4. Imation Superdisk USB Drive Metal Casing Replacement: 4 단계, 이미지 2개 중 1개 Imation Superdisk USB Drive Metal Casing Replacement: 4 단계, 이미지 2개 중 2개
    • Slide the bottom plastic panel of the shell down so it is free of the end cap and the top panel.
    • Lift panel free of device.
  5. Imation Superdisk USB Drive Metal Casing Replacement: 5 단계, 이미지 2개 중 1개 Imation Superdisk USB Drive Metal Casing Replacement: 5 단계, 이미지 2개 중 2개
    • Identify the end cap by noting the label "SuperDisk Drive" above where you would insert a floppy disk.
    • Remove the plastic end cap by sliding it forward, freeing from the rest of the device.
  6. Imation Superdisk USB Drive Metal Casing Replacement: 6 단계, 이미지 2개 중 1개 Imation Superdisk USB Drive Metal Casing Replacement: 6 단계, 이미지 2개 중 2개
    • Slide the metal housing out of the plastic shell.
  7. Imation Superdisk USB Drive Metal Casing Replacement, Metal Casing: 7 단계, 이미지 2개 중 1개 Imation Superdisk USB Drive Metal Casing Replacement, Metal Casing: 7 단계, 이미지 2개 중 2개
    • Slide metal panel out of the metal casing.
  8. Imation Superdisk USB Drive Metal Casing Replacement: 8 단계, 이미지 2개 중 1개 Imation Superdisk USB Drive Metal Casing Replacement: 8 단계, 이미지 2개 중 2개
    • Slide disk drive out of metal casing.
결론
작성자
4다른 기여자 명과 함께
Ryan
회원 가입일: 02/13/14
1 평판
안내서 1개를 작성함
Ohio State, Team 1-2, Buehl Spring 2014 Ohio State, Team 1-2, Buehl Spring 2014 회원
OSU-BUEHL-S14S1G2
4 회원들
안내서 14개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 3
지난 30일: 4
전체 시간: 471
