주요 콘텐츠로 건너뛰기
Imation Superdisk USB Drive Plastic Housing Replacement
필요한 것
  1. Imation Superdisk USB Drive Plastic Housing Replacement, Plastic Housing: 1 단계, 이미지 1/2 Imation Superdisk USB Drive Plastic Housing Replacement, Plastic Housing: 1 단계, 이미지 2/2
    • Flip the device over so the bottom is facing up.
    • You will know it is the bottom because there will be six silver screws visible.
  2. Imation Superdisk USB Drive Plastic Housing Replacement: 2 단계, 이미지 1/2 Imation Superdisk USB Drive Plastic Housing Replacement: 2 단계, 이미지 2/2
    • Remove the USB converter device by gently pulling it out.
    • Do not pull the converter device out by the cord.
  3. Imation Superdisk USB Drive Plastic Housing Replacement: 3 단계, 이미지 1/2 Imation Superdisk USB Drive Plastic Housing Replacement: 3 단계, 이미지 2/2
    • Remove the six silver screws using a small Phillips head screwdriver.
  4. Imation Superdisk USB Drive Plastic Housing Replacement: 4 단계, 이미지 1/2 Imation Superdisk USB Drive Plastic Housing Replacement: 4 단계, 이미지 2/2
    • Slide the bottom plastic panel of the shell down so it is free of the end cap and the top panel.
    • Lift panel free of device.
  5. Imation Superdisk USB Drive Plastic Housing Replacement: 5 단계, 이미지 1/2 Imation Superdisk USB Drive Plastic Housing Replacement: 5 단계, 이미지 2/2
    • Remove the plastic end cap by sliding it forward, freeing from the rest of the device.
    • You can identify the end cap by noting the label "SuperDisk Drive" above where you would insert a floppy disk.
  6. Imation Superdisk USB Drive Plastic Housing Replacement: 6 단계, 이미지 1/2 Imation Superdisk USB Drive Plastic Housing Replacement: 6 단계, 이미지 2/2
    • Slide the metal housing out of the plastic shell.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Caitlin Horwatt
회원 가입일: 02/11/14
137 평판
안내서 2개 작성하였습니다
Ohio State, Team 1-2, Buehl Spring 2014 Ohio State, Team 1-2, Buehl Spring 2014 회원
OSU-BUEHL-S14S1G2
4 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 10
30일 전: 19
전체 시간: 817
