주요 콘텐츠로 건너뛰기
Lite-On LightScribe SHM-165H6S Faceplate/Eject button Replacement
필요한 것
  1. Lite-On LightScribe SHM-165H6S Faceplate/Eject button Replacement, Faceplate/Eject button: 1 단계, 이미지 1/2 Lite-On LightScribe SHM-165H6S Faceplate/Eject button Replacement, Faceplate/Eject button: 1 단계, 이미지 2/2
    • Insert an open paper clip into small hole on left side of faceplate.
    • The tray should click open, use your hands to gently extend it fully.
  2. Lite-On LightScribe SHM-165H6S Faceplate/Eject button Replacement: 2 단계, 이미지 1/3 Lite-On LightScribe SHM-165H6S Faceplate/Eject button Replacement: 2 단계, 이미지 2/3 Lite-On LightScribe SHM-165H6S Faceplate/Eject button Replacement: 2 단계, 이미지 3/3
    • Push in black tabs on left, right and bottom of outer chassis to unhook faceplate.
  3. Lite-On LightScribe SHM-165H6S Faceplate/Eject button Replacement: 3 단계, 이미지 1/1
    • Pull face plate away from main chassis.
  4. Lite-On LightScribe SHM-165H6S Faceplate/Eject button Replacement: 4 단계, 이미지 1/3 Lite-On LightScribe SHM-165H6S Faceplate/Eject button Replacement: 4 단계, 이미지 2/3 Lite-On LightScribe SHM-165H6S Faceplate/Eject button Replacement: 4 단계, 이미지 3/3
    • Locate the two tabs on the underside of the tray cover.
    • Pry the tabs loose and remove cover.
  5. Lite-On LightScribe SHM-165H6S Faceplate/Eject button Replacement: 5 단계, 이미지 1/1
    • Remove and replace faceplate.
결론
aaa
회원 가입일: 10/20/11
171 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 4
전체 시간: 2,163
