소개
This guide details the necessary steps to remove the front facing camera from the Leader Impression i7 tablet. Make sure you have a replacement camera ready before starting this guide.
부품
부품은 필요하지 않습니다.
  1. Wedge the plastic opening tool into the seam nearest to the screen surface and begin to pry off the back of the device.
    • Wedge the plastic opening tool into the seam nearest to the screen surface and begin to pry off the back of the device.
  2. Move the plastic opening tool along the perimeter of the device, loosening the entire back as you go.
    • Move the plastic opening tool along the perimeter of the device, loosening the entire back as you go.
    • After the entire perimeter has been pried, remove the back of the device.
    • Be careful not to disconnect the speaker and microphone cables attached to the back of the tablet.
    • Remove the transparent, orange tape from the edge of the battery.
    • Pry the battery off, using the plastic opening tool.
    • Desolder the positive and negative leads.
    • Pull the battery away from the adhesive.
    • Peel the gray tape from the top of the battery.
    • Gently pull the front camera connection out of its socket.
    • Lift the camera unit from its housing. The unit should come out with minimal force.
결론
Cole Beaver
회원 가입일: 2018년 11월 05일
363 평판
안내서 3개 작성하였습니다
IUPUI, Team S1-G5, Baechle Fall 2018 IUPUI, Team S1-G5, Baechle Fall 2018 회원
IUPUI-BAECHLE-F18S1G5
3 회원들
안내서 3개 작성하였습니다
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 21
전체 시간: 32
