주요 콘텐츠로 건너뛰기
Impression i7 USB Port Replacement
필요한 것
  1. Impression i7 USB Port Replacement, Battery: 1 단계, 이미지 1/1
    • Wedge the plastic opening tool into the seam nearest to the screen surface and begin to pry off the back of the device.
  2. Impression i7 USB Port Replacement: 2 단계, 이미지 1/1
    • Move the plastic opening tool along the perimeter of the device, loosening the entire back as you go.
  3. Impression i7 USB Port Replacement: 3 단계, 이미지 1/1
    • After the entire perimeter has been pried, remove the back of the device.
    • Be careful not to disconnect the speaker and microphone cables attached to the back of the tablet.
  4. Impression i7 USB Port Replacement: 4 단계, 이미지 1/2 Impression i7 USB Port Replacement: 4 단계, 이미지 2/2
    • Remove the transparent, orange tape from the edge of the battery.
    • Pry the battery off, using the plastic opening tool.
  5. Impression i7 USB Port Replacement: 5 단계, 이미지 1/1
    • Desolder the positive and negative leads.
  6. Impression i7 USB Port Replacement: 6 단계, 이미지 1/2 Impression i7 USB Port Replacement: 6 단계, 이미지 2/2
    • Pull the battery away from the adhesive.
    • Peel the gray tape from the top of the battery.
  7. Impression i7 USB Port Replacement, USB Port: 7 단계, 이미지 1/1
    • Remove the five 5 mm screws from the motherboard, using the #0 Phillips Screwdriver.
  8. Impression i7 USB Port Replacement: 8 단계, 이미지 1/2 Impression i7 USB Port Replacement: 8 단계, 이미지 2/2
    • Using the plastic opening tool tool, pry back the 4 four clips to release the motherboard.
  9. Impression i7 USB Port Replacement: 9 단계, 이미지 1/2 Impression i7 USB Port Replacement: 9 단계, 이미지 2/2
    • Desolder the eight solder joints holding the USB Port in place.
결론
Cole Beaver
회원 가입일: 11/05/18
417 평판
안내서 3개 작성하였습니다
IUPUI, Team S1-G5, Baechle Fall 2018 IUPUI, Team S1-G5, Baechle Fall 2018 회원
IUPUI-BAECHLE-F18S1G5
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 178
