Turn on your mirror to see which light bulb is not working.
Now that you know which bulb isn't working, turn off the mirror and disconnect it from the wall outlet to avoid any injuries.
Turn the light bulb counter clockwise to remove it from the mirror.
Make sure the light bulb that you bought is the same model and wattage as the one you removed.
Place the new light bulb in its socket and turn it clockwise to secure it.
Make sure that the bulb is secured in place.
If it's not well-secured, the bulb won't light up when the mirror is turned on.
Plug the mirror back into the outlet.
Turn on the mirror and check that the new bulb works.
취소: 해당 안내서를 완성하지 않았습니다.
다른 기여자 1명과 함께
회원 가입일: 04/17/21
157 평판
안내서 1개 작성함
배지: 2
CSULA-HARRIS-S21S1G80
1 회원
안내서 1개 작성하였습니다
해당 안내서를 사이트/포럼에 작은 위젯으로 포함하려면 크기를 선택하고 아래 코드를 복사하십시오.
24 시간 전: 1
7일 전: 10
30일 전: 22
전체 시간: 941
