주요 콘텐츠로 건너뛰기
Impuls Blender Electronic wire Replacement
필요한 것
  1. Impuls Blender Electronic wire Replacement, Electronic wire: 1 단계, 이미지 1/3 Impuls Blender Electronic wire Replacement, Electronic wire: 1 단계, 이미지 2/3 Impuls Blender Electronic wire Replacement, Electronic wire: 1 단계, 이미지 3/3
    • Here you see the Impuls blender
    • First, seperate the the blender jar from the bottom part by turning it and put it aside.
  2. Impuls Blender Electronic wire Replacement: 2 단계, 이미지 1/3 Impuls Blender Electronic wire Replacement: 2 단계, 이미지 2/3 Impuls Blender Electronic wire Replacement: 2 단계, 이미지 3/3
    • Turn the bottom part over and look at the bottom.
    • Take the rubber parts out of the 4 holes to reveal the screws.
    • Take the 4 screws out using a Phillips screwdriver.
  3. Impuls Blender Electronic wire Replacement: 3 단계, 이미지 1/3 Impuls Blender Electronic wire Replacement: 3 단계, 이미지 2/3 Impuls Blender Electronic wire Replacement: 3 단계, 이미지 3/3
    • Take the blue bottom part off the rest of the product to reveal the inside.
    • Unscrew the black piece to be able to slide the blue part away from the rest.
  4. Impuls Blender Electronic wire Replacement: 4 단계, 이미지 1/3 Impuls Blender Electronic wire Replacement: 4 단계, 이미지 2/3 Impuls Blender Electronic wire Replacement: 4 단계, 이미지 3/3
    • When you look to the inside, you see that there are two components; the buttons and the motor.
    • Unscrew the part that contains the buttons and take it off.
  5. Impuls Blender Electronic wire Replacement: 5 단계, 이미지 1/3 Impuls Blender Electronic wire Replacement: 5 단계, 이미지 2/3 Impuls Blender Electronic wire Replacement: 5 단계, 이미지 3/3
    • Take out the 3 screws that are deep inside.
    • Take off the blue part on top that was fixed with those screws.
    • Pull the black disc out by using the screwdriver as lever from multiple sides.
    • This will take some force, so do not be afraid it will break.
  6. Impuls Blender Electronic wire Replacement: 6 단계, 이미지 1/3 Impuls Blender Electronic wire Replacement: 6 단계, 이미지 2/3 Impuls Blender Electronic wire Replacement: 6 단계, 이미지 3/3
    • When you have taken off the black piece and revealed the 4 screws, unscrew them all.
    • Take out the motor part and the rest of the electronics.
  7. Impuls Blender Electronic wire Replacement: 7 단계, 이미지 1/3 Impuls Blender Electronic wire Replacement: 7 단계, 이미지 2/3 Impuls Blender Electronic wire Replacement: 7 단계, 이미지 3/3
    • Find the fraction in the wire.
    • Cut off the broken part
    • Strip both sides of the wire that have to be attached again.
  8. Impuls Blender Electronic wire Replacement: 8 단계, 이미지 1/2 Impuls Blender Electronic wire Replacement: 8 단계, 이미지 2/2
    • If you will use a shrink sleeve to cover the electronic wire, it has to be put on the wire first. Otherwise if electrical tape is used, this can be done afterwards.
    • Solder the two wires with a soldering iron.
    • Shrink the sleeve with a heater or put the electrical tape around the soldered wire.
결론
To reassemble your device, follow the instructions in reverse order.
다른 한 분이 해당 안내서를 완성하였습니다.
Daan van der Sande
회원 가입일: 03/08/17
101 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 13
30일 전: 37
전체 시간: 1,071
