주요 콘텐츠로 건너뛰기
In-Ear Headphone Control and Mic Block Disassembly
필요한 것
  1. In-Ear Headphone Control and Mic Block Disassembly, The Control Unit: 1 단계, 이미지 1/1
    • Find the edge of the control unit and get a very fine flathead screw driver (or a plastic pry tool which would do less damage)
  2. In-Ear Headphone Control and Mic Block Disassembly, Opening The Unit: 2 단계, 이미지 1/1
    • Wedge the tool in the corner and start sliding it to the left.
    • As you do this slowely twist the screw driver back and forth to release the clips.
    • Try not to let the tool slip into the control unit as this may damage the circuit board inside.
  3. In-Ear Headphone Control and Mic Block Disassembly, Removing The Cover: 3 단계, 이미지 1/2 In-Ear Headphone Control and Mic Block Disassembly, Removing The Cover: 3 단계, 이미지 2/2
    • Repeat step 2 and the control unit should open as seen in the image.
    • Remove the plastic sleeves and you will be left with just the circuit board (see second image).
  4. In-Ear Headphone Control and Mic Block Disassembly, Identify Broken Wire: 4 단계, 이미지 1/1
    • It is quickly seen that one of the wires has broken away from the circuit board (see image)
  5. In-Ear Headphone Control and Mic Block Disassembly, Resolder the Broken Wire: 5 단계, 이미지 1/1
    • Once the wire is found a steady hand and a fine tipped soldering iron should be used to reattach the wire.
    • Ensure that you do not head to circuit board for too long as it may cause damage (be as quick as possible!)
    • After this, the circuit board and wires should be replaced as they were before. Press the plastic cover halves together and it should click back into place.
    • And they are fixed!
결론
Your headphones should now be working!
다른 3명이 해당 안내서를 완성하였습니다.
Alexander
회원 가입일: 09/10/18
233 평판
안내서 1개 작성함
One Comment
Thanks a lot this worked perfectly thank you very much
MD Ratul - 답글
댓글 쓰기
조회 통계:
24 시간 전: 13
7일 전: 97
30일 전: 408
전체 시간: 10,223
