주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
In-Place Fan Cover Removal
필요한 것
  1. In-Place Fan Cover Removal, Remove fan bumper: 1 단계, 이미지 3개 중 1개 In-Place Fan Cover Removal, Remove fan bumper: 1 단계, 이미지 3개 중 2개 In-Place Fan Cover Removal, Remove fan bumper: 1 단계, 이미지 3개 중 3개
    • Carefully remove the rubber fan bumper from the edge of the heat sink.
    • The bumper is gently held in place by the lips in the third image which wrap under the heat sink. There is no adhesive, so removal and reseating should be easy.
  2. In-Place Fan Cover Removal, iSight Cable: 2 단계, 이미지 2개 중 1개 In-Place Fan Cover Removal, iSight Cable: 2 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use the tip of a spudger to push on either side of the the iSight camera cable connector to walk it out of its socket on the logic board.
    • The cable connector is small and delicate, so make sure to nudge it out a little bit at a time from each side, alternating until it is fully out. A spudger or tweezers are ideal for this.
  3. In-Place Fan Cover Removal: 3 단계, 이미지 2개 중 1개 In-Place Fan Cover Removal: 3 단계, 이미지 2개 중 2개
    • Peel the iSight camera cable off the fan housing to fold it out of the way.
    • You can optionally use hot air to soften the adhesive and/or a spudger to help separate the cable from the fan housing.
  4. In-Place Fan Cover Removal, Disconnect I/O board cable: 4 단계, 이미지 2개 중 1개 In-Place Fan Cover Removal, Disconnect I/O board cable: 4 단계, 이미지 2개 중 2개
    • One of the screws holding the top shell of the fan assembly is hidden just behind the I/O board cable.
    • Remove the two 2.1 mm T5 Torx screws securing the I/O board cable bracket to the logic board.
    • Remove the I/O board cable bracket.
  5. In-Place Fan Cover Removal: 5 단계, 이미지 2개 중 1개 In-Place Fan Cover Removal: 5 단계, 이미지 2개 중 2개
    • Use the flat end of a spudger to pop the I/O board connector straight up off its socket on the logic board.
    • Be careful to only pry up on the I/O board cable, not on the socket itself or you risk damaging your logic board.
  6. In-Place Fan Cover Removal: 6 단계, 이미지 2개 중 1개 In-Place Fan Cover Removal: 6 단계, 이미지 2개 중 2개
    • Lift the logic board end of the I/O board cable straight up to bend it out of the way.
    • To avoid damage to the cable, fold only at the bend in the I/O board end of the cable. It will only be in the way momentarily, so don't try forcing it to stay.
  7. In-Place Fan Cover Removal: 7 단계, 이미지 1개 중 1개
    • Remove the following screws securing the fan assembly cover to the rest of the assembly:
    • One 5.0 mm T5 Torx screw.
    • This screw holds the upper case, main fan assembly, and fan assembly together, and so must be removed.
    • 3 Phillips #000 screws.
    • The bottom right screw is just under the I/O board cable, and will be visible after it has been lifted out of the way.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Stefan Countryman
회원 가입일: 11/24/17
517 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 18
지난 30일: 59
전체 시간: 2,075
