주요 콘텐츠로 건너뛰기
InFocus IN3104 Cooling Fan Replacement
필요한 것
  1. InFocus IN3104 Cooling Fan Replacement, Top Cover: 1 단계, 이미지 1/3 InFocus IN3104 Cooling Fan Replacement, Top Cover: 1 단계, 이미지 2/3 InFocus IN3104 Cooling Fan Replacement, Top Cover: 1 단계, 이미지 3/3
    • Turn the projector so that the lens is facing you.
    • On the left side of the projector, there is a screw and a knob inside of the small grate.
    • Use a Phillips #1 screwdriver to remove the 6 mm screw that secures top cover.
    • Remove the service cover.
  2. InFocus IN3104 Cooling Fan Replacement: 2 단계, 이미지 1/3 InFocus IN3104 Cooling Fan Replacement: 2 단계, 이미지 2/3 InFocus IN3104 Cooling Fan Replacement: 2 단계, 이미지 3/3
    • Use a Phillips #1 screwdriver to remove the seven 6 mm screws.
    • Use a Phillips #1 screwdriver to remove the two 5 mm screws.
    • Remove the top cover.
    • Do not pull the cover too hard. It may damage the wire that is connected to the motherboard.
  3. InFocus IN3104 Cooling Fan Replacement, InFocus IN3104 Metal Cover Disassembly: 3 단계, 이미지 1/2 InFocus IN3104 Cooling Fan Replacement, InFocus IN3104 Metal Cover Disassembly: 3 단계, 이미지 2/2
    • Use a Phillips #1 screwdriver to remove the nine 6 mm screws.
    • Lift up the metal cover and set it aside to reveal the motherboard.
  4. InFocus IN3104 Cooling Fan Replacement: 4 단계, 이미지 1/3 InFocus IN3104 Cooling Fan Replacement: 4 단계, 이미지 2/3 InFocus IN3104 Cooling Fan Replacement: 4 단계, 이미지 3/3
    • Carefully pry up the black plastic locking bar of the ZIF connector on the motherboard with a plastic spudger.
    • Pull out the blue-tipped, white ribbon cable from the connector.
    • Remove the metal cover.
  5. InFocus IN3104 Cooling Fan Replacement, Cooling Fan: 5 단계, 이미지 1/2 InFocus IN3104 Cooling Fan Replacement, Cooling Fan: 5 단계, 이미지 2/2
    • Use a Phillips #1 screwdriver to remove the three 6 mm screws on the metal cover beside the lamp.
    • The screws are in a tight location, so you may need a thin screwdriver or an extension to remove them.
  6. InFocus IN3104 Cooling Fan Replacement: 6 단계, 이미지 1/3 InFocus IN3104 Cooling Fan Replacement: 6 단계, 이미지 2/3 InFocus IN3104 Cooling Fan Replacement: 6 단계, 이미지 3/3
    • Unplug the yellow, red, and black colored cable bundle from the motherboard.
    • Remove the cooling fan from the device by lifting it out.
결론
Tae Min Kim
회원 가입일: 01/24/20
409 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 8
전체 시간: 408
