주요 콘텐츠로 건너뛰기
InFocus IN3104 Top Cover Replacement
필요한 것
  1. InFocus IN3104 Top Cover Replacement, Top Cover: 1 단계, 이미지 1/3 InFocus IN3104 Top Cover Replacement, Top Cover: 1 단계, 이미지 2/3 InFocus IN3104 Top Cover Replacement, Top Cover: 1 단계, 이미지 3/3
    • Turn the projector so that the lens is facing you.
    • On the left side of the projector, there is a screw and a knob inside of the small grate.
    • Use a Phillips #1 screwdriver to remove the 6 mm screw that secures top cover.
    • Remove the service cover.
  2. InFocus IN3104 Top Cover Replacement: 2 단계, 이미지 1/3 InFocus IN3104 Top Cover Replacement: 2 단계, 이미지 2/3 InFocus IN3104 Top Cover Replacement: 2 단계, 이미지 3/3
    • Use a Phillips #1 screwdriver to remove the seven 6 mm screws.
    • Use a Phillips #1 screwdriver to remove the two 5 mm screws.
    • Remove the top cover.
    • Do not pull the cover too hard. It may damage the wire that is connected to the motherboard.
결론
Tae Min Kim
회원 가입일: 01/24/20
409 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 212
